Programs and Features - Enable or Disable
    How to Enable or Disable "Programs and Features" in Windows 7
    This will show you how to enable or disable all or specific users from being able to access Programs and Features in the Control Panel to view, uninstall, change, or repair programs that are currently installed in Windows 7.
    You must be logged in as an administrator to be able to do the steps in this tutorial.
    EXAMPLE: Programs and Features Enabled and Disable
    OPTION ONE
    To Enable or Disable "Programs and Features" Using REG Download
    NOTE: This option will affect all users on the computer.
    1. To Enable Programs and Features
    Enable_Programs_and_Features.reg
    B) Go to step 3.
    2. To Disable Programs and Features
    Disable_Programs_and_Features.reg
    5. Click on Run, Yes (UAC), Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    To Enable or Disable "Programs and Features" in Group Policy
    2. In the left pane, click on to expand User Configuration, Administrative Templates, Control Panel, and Programs. (see screenshot below)
    3. In the right pane, right click on Hide "Programs and Features" page and click on Edit. (see screenshot above)
    4. To Enable Programs and Features
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    B) Go to step 6.
    5. To Disable Programs and Features
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click on OK. (see screenshot below)
  1. Posts : 9
    Windows 7 X64 version 6.1.7601
    Yes, easy to follow instructions, but wouldn't that disable control panel for ALL users, INCLUDING the admin?
    If the previous is true, that's not very practical for what I have in mind. I want to prevent the Guest account from making any modifications to the computer. And I cannot use Parental Controls on a Guest account.
  2. Posts : 72,052
    Hello Xavier, and welcome to Seven Forums.
    Option One yes, but you could use OPTION TWO (if available in your edition of Windows 7) will allow you to specify.
    By default, a guest account cannot make changes that affect the computer anyways. When they log out, any changes they made to the guest account itself are automatically undone. There's really not any need to do anything else though.
    To continue at your existing thread for this issues below.
    How to prevent Guest account from making modifications to the computer
  3. Posts : 2
    Alabama
    I've tried doing this both ways, but guest can still access programs and features, I'm the only one locked out and I have no idea why.
  4. Posts : 72,052
    Hello JT, and welcome to Seven Forums. :)
    Did you use step 3 in OPTION ONE, approved all prompts while merging the .reg file, and restart the computer afterwards?
  5. Posts : 2
    Alabama
    Yes, I did that, and it's only locking me out, when I log in via the guest account, it's still able to view programs and features just fine, while I remain locked out.
    *EDIT* I used method two and applied it to non Admin users and now guest can't view it. Turned out I wasn't doing method two correctly. Problem solved. :)
  6. Posts : 72,052
    Great news. :)
    OPTION ONE sets the same thing in the registry as OPTION TWO, so I'm not sure what went wrong unless a step was missed by mistake.
