Elevated Command Prompt
Page 4 of 8 FirstFirst ... 23456 ... LastLast
  1. Posts : 19,383
       #30
    Hi Brink,
    Another useful shortcut I discovered :
    1. Place a shortcut to cmd on your desktop, or pin it to the TaskBar.
    2. Hold down SHIFT+CTRL+ALT and click the shortcut/pin.
    3. Accept the UAC prompt
    An elevated command prompt is opened.
    Regards,
    Golden
  2. Posts : 72,052
       #31
    Golden said:
    Hi Brink,
    Regards,
    Golden
    Hello Golden,
    ....or
    Elevated Command Prompt Shortcut
  3. Posts : 11
    Win7Pro64SP1
       #32
    Thank for all your help. Resolved my problem, see: https://www.sevenforums.com/crashes-d...r-safe-ok.html
  4. Posts : 72,052
       #33
    That's great news Harald.
  5. Posts : 19,383
       #34
    Brink said:
    Golden said:
    Hi Brink,
    Regards,
    Golden
    Hello Golden,
    ....or
    {face palm} Doh. :)
  6. Posts : 72,052
       #35
    LOL.
  7. Posts : 21,004
       #36
    There is no end to the universe is there
    My heavens I have to be honest Shawn and admit I was stumped by "elevated cmd" so found this tut.
    Mate like the universe your knowledge is boundless - thanks so much
  8. Posts : 72,052
       #37
    You're most welcome John. :)
  9. Posts : 5
    Windows 7 pro 64-bit
       #38
    A minor correction to an excellent webpage on an excellent forum:
    This should probably read:
    "7. In the Start Menu search box area type cmd, then right click on cmd.exe (at top), and click on Run as administrator. (See screenshot below)"
    Thank you again
  10. Posts : 72,052
       #39
    Thank you WindowsPains. Corrected. :)
