Menus Open to the Left or Right Side
    How to Set Menus to Open to Left or Right Side in Windows 7 and Windows 8
    This tutorial will show you how to set all menus (ex: context menu, Menu bar, etc...) to open to the left or right side of where you click at in Windows 7 and Windows 8.
       Warning
    If the menu does not have enough room to fully open at the border of the window or display screen, it will compensate and open from the opposite direction of the border instead. This will override whatever side you have the menu set to open on below.
    EXAMPLE: Right-handed
    NOTE: Menus open to the left of your hand.
    EXAMPLE: Left-handed
    NOTE: Menus open to the right of your hand.
    OPTION ONE
    Set Menus to Open to Left or Right Side in Tablet PC Settings
    1. Open Tablet PC Settings, and click/tap on the Other tab. (see screenshot below)
    2. To Have Menus Open to the Left
    A) Select (dot) Right-handed, and click/tap on OK.
    3. To Have Menus Open to the Right
    A) Select (dot) Left-handed, and click/tap on OK.
    OPTION TWO
    Set Menus to Open to Left or Right Side using a REG File
    1. Do step 2 or 3 below for what you would like to do.
    A) Click/tap on the Download button below to download the file below, and go to step 4 below.
    Menus_Open_To_Left.reg
    Menus_Open_To_Right.reg
    4. Save the .reg file to your desktop.
    5. Double click/tap on the downloaded .reg file to merge it.
    6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.
    7. Log off and log on, or restart the computer to apply.
    8. When done, you can delete the downloaded .reg file if you like.
    OPTION THREE
    Set Menus to Open to Left or Right Side in Registry Editor
    1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
    2. If prompted by UAC, then click/tap on Yes.
    3. In regedit, navigate to the location below. (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows
    4. To Have Menus Open to the Left
    A) In the right pane of Windows, right click or press and hold on an empty space, and click/tap on New and String Value. Type MenuDropAlignment, and press Enter. (see screenshot below)
    NOTE: If you already have MenuDropAlignment, then skip this step and go to step 4B instead.
    B) In the right pane, double click/tap on MenuDropAlignment and to modify it. (see screenshot above)
    C) Type 1, click on OK, and go to step 6 below. (see screenshot below)
    5. To Have Menus Open to the Right
    A) In the right pane of Windows, right click on MenuDropAlignment and click on Delete and Yes. (see screenshot below step 4B)
    OR
    B) Repeat all steps in step 4, type 0 (zero) in step 4C instead, and go to step 6 below.
    6. Close regedit.
  1. Posts : 134
    Windows 7 64-bit Windows 7 32-bit
    I cant find the "Tablet PC Settings" folder, I'm guessing it only exists on tablet PC's, is there a way to add it to non tablet PC's? Cause I've always wanted these to show up to the left of the mouse.
  2. Posts : 72,058
    Hello Kookster,
    Double check in Windows Features to make sure that you have the Tablet PC Components option checked. Afterwards, it should be available in the Control Panel.
  3. Posts : 13,354
    Windows 7 Professional x64
    Shawn, I do have the feature turned on, and I still don't see anything in Control Panel. A search for it was fruitless.
  4. Posts : 72,058
    Um, it seems that MS removed Tablet PC Settings in the Control Panel.
    Well, I'll have to do some more digging on this. These are the settings for this in the registry in Vista.
    RIGHT_HANDED
    [HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows]
    "MenuDropAlignment"="1"
    LEFT_HANDED
    "MenuDropAlignment"="0"
    UPDATE:
    They work, but you have to log off and on and not just kill/restart explorer. Tutorial has been updated with this new way. :)
  5. Posts : 13,354
    That works very well now Shawn. Thanks!
  6. Posts : 72,058
    You're most welcome. :)
  7. Posts : 134
    Thanks Brink works just fine now.
  8. Posts : 72,058
  9. NoN
    Brink said:
    Hello Kookster,
    Hi Shawn, i was hanging around reading a thread...and linked here.
    Seems Tablet PC Components does exist on my Win 7 (it is checked on mine), and aswell the registry key:
    "RIGHT_HANDED
    "MenuDropAlignment"="1"."
    No need to create the key now, just have to set to 0 or 1....:)
