Manage - Fix "File does not have a program associated"
Page 4 of 4 FirstFirst ... 234
  1. Posts : 4
    Windows 7 home premium-64
       #30
    I was running malware as i was posting the above message. It seems it found 2 other items and it took care of it.
    I will dl the MSSW anything to help, I don't need a virus to take down this laptop as it's only been mine for a month :/
    Thank you for all your help you saved my sanity as I've been at this since yesterday but found this place this am.
  2. Posts : 72,036
       #31
    You're welcome Marnel. I hope that it comes back as clean afterwards. Just to be safe, it wouldn't hurt to scan your system each day for a few days to help make sure that it's still clean.
  3. Posts : 2
    Windows 7 x64
       #32
    is it bad if I can't find Inkfile under HKEY_CLASSES_ROOT? I was trying to follow option 2 tutorial when I ran into that problem :/
  4. Posts : 72,036
       #33
    Hello Gouron,
    It's Lnkfile (L) instead of Inkfile (I) , but you may not have reached lnkfile yet. You would need to scroll past all of the file extenstions listed first before the alphabet starts over to then find lnkfile. :)
  5. Posts : 115
    7 Ultimate x64 sp1
       #34
    The reg file worked fine on my system
    "manage works again"
    But after restart little arrows on shortcuts are back.
    Again remove arrows, manage not working.
    So I think its a linked thing manage or arrows.
  6. Posts : 72,036
       #35
    Hello Joe,
    It is if you use the old XP method to remove shortcut arrows. See the blue note box at the top of the tutorial for info and a link on how to remove shortcut arrows in Windows 7 instead. :)
