Manage - Fix "File does not have a program associated"
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 72,058
    Rodekyll,
    Download and merge the reg option in the tutorial below to add it back to the registry, and hopefully allow you to be able to user the one here. :)
  2. Posts : 5
    windows 7
    I dont have a merge option when i right click
  3. Posts : 72,058
       #12
    Hello Rodekyll,
    Double check in Default Programs to make sure that the .reg file extension has it's "Current Default" program set as Registry Editor (C:\Windows\regedit.exe). Afterwards, see if you are able to merge it.
  4. Posts : 5
    windows 7
    I went and manually put in the IsShortcut and still nothing there is no .reg or .exe in the default and when I download all the file in the tutorial there is no option for merge there is also no .reg in the regedit
  5. Posts : 5
    windows 7
       #14
    The only options I get when i right click are the following open norton internet security, restore previous version cut copy create shortcut delete rename properties. This is very fustrating
  6. Posts : 72,058
       #15
    Rodekyll,
    As a test, temporarly disable or uninstall Norton to see if you have this issue afterwards.
    If you do not have an exe or reg entry in the registry, then you may be infected with a virus or some other malware. I would recommend scanning your computer with a good antivirus program, and a good anti-malware program like the free Malwarebytes.
    Afterwards, see if doing a system restore at boot using a restore point dated before you had this issue may be able to fix this for you.
  7. Posts : 7
    Windows 8 (64bit)
       #16
    It Works!
    thanks for the tutorial.
    It works for me. I've been looking for this fix for a looooong time!
    Thanks once again!
    Henry
  8. Posts : 72,058
       #17
    You're most welcome Henry, and welcome back to Seven Forums. :)
  9. Posts : 21
    Windows 7 Ultimate 64 bit
       #18
    Hi
    Here is another workaround :
    Go to :
    RUN\REGEDIT\[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Manage\command]
    and modify the existing value in
    mmc %SystemRoot%\system32\compmgmt.msc
    Works at once , no need to reboot .
    Best regards ,
    Fanaudi .
  10. Posts : 72,058
       #19
    Thank you Fanaudi. I have added this into the tutorial to cover this as a possible cause as well. :)
