How to Create a "Safely Remove Hardware" Shortcut in Vista, Windows 7, and Windows 8
Safely Remove Hardware allows you to safely shutdown and eject a storage device before just unplugging or disconnecting it to help prevent accidental data loss if data were still being copied or saved to or from the device. For example, if you have
write caching enable on the device.
This tutorial will show you how to create or download a
Safely Remove Hardware shortcut that you can use where you like in Windows.
EXAMPLE: Safely Remove Hardware
OPTION ONE
To Download the "Safely Remove Hardware" Shortcut
1. Click/tap on the download button below to download the file below.
2. Save the .zip file to your desktop.
3. Open the .zip file and extract the Safely Remove Hardware shortcut to the desktop
4. Unblock the
Safely Remove Hardware shortcut.
5. If you would like a better custom
256x256 pixel icon instead of the default smaller icon, then go to step 8 in OPTION TWO below to download and use it instead. :)
6. In
Vista and
Windows 7, you can now
Pin to Taskbar (Windows 7 only) or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
7. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch,
8. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create the "Safely Remove Hardware" Shortcut
1. Right click or press and hold on an empty area on your desktop, and click/tap on
New and
Shortcut.
2. Copy and Paste the location below into the location area, and click/tap on the
Next button. (see screenshot below)
%windir%\System32\rundll32.exe shell32.dll,Control_RunDLL hotplug.dll
3. Type
Safely Remove Hardware for the name, and click/tap on the
Finish button. (see screenshot below)
NOTE: You can name this anything you would like though. 4. Right click or press and hold on the new
Safely Remove Hardware shortcut, and click/tap on
Properties.
5. Click/tap on the
Shortcut tab, then click/tap on the
Change Icon button. (see screenshot below)
6. To Use the Default Icon A) In the line under "Look for icons in this file", type in the location below, press
Enter, and go to
step 8 below. (see left screenshot below step 8)
%SystemRoot%\System32\hotplug.dll
7. To Download or Use a Custom Icon
NOTE: You can skip this step and go to step 6 if you do not want or need a better 256x256 pixel icon to use instead of the smaller default one.
A) You could click/tap on the Download button below to download and use this custom
256x256 pixel Safely_Remove_Hardware.ico file in a ZIP file below as this shortcut's icon if you like.
NOTE: The icon will need to remain saved at the same location for the icon to continue to display on the shortcut.
B) In the line under "Look for icons in this file", click/tap on
Browse and navigate to the location of the saved
256x256 pixel icon you want to use. (see right screenshot below step 8)
8. Select the icon in blue below, and click/tap on
OK. (see screenshots below)
NOTE: Left sceeenshot for step 4, and right screenshot for step 5.
9. Click/tap on
OK. (see screenshot below)
10. In
Vista and
Quick Launch,
11. In
Windows 8, you can
Quick Launch,
