#240
Hi, I just got the Samsung LCD SynyMaster 2233RZ 120hz. The monitor came with a DVI-DL link but my laptop that I want to connect it to does not support DVI. I went ahead and bought a DVI-D to HDMI Cable. It won't let me surpass 60hz when I try to change the refresh rate. I tried following this guide but it seems so confusing. Can anyone help?
Is there anyway to restore default settings? When I tried using this guide I was careless and experimented with the wrong things.
So I went ahead and plugged my old CRT in that i KNOW gets 100hz on 1024x768. I ran through all the directions correctly and when I restart it shows in drop-down menu that I have the ability to put it to a 100hz. But once I click apply my screen says out of range/frequency? I know for a fact it has something to do with my computer not the monitor itself. Any ideas?
Without using the modified monitor driver you created as a product of running through the tutorial, what were the capabilities reported by the monitor? From you recent posts it appears that there are at least two monitors in question here, an "old" CRT, a SyncMaster 2233RZ and maybe something else. The SyncMaster supports only DVI but a true DVI to HDMI adapter cable should work just fine supposing that it is straight wired owing to the fact that the digital video signal carried by HDMI is identical to that carried by DVI-D. I'd verify the SyncMaster's performance on a computer with native DVI and make a technical inquiry about your adapter cable. What does MonInfo claim are your SyncMaster's capabilities and how do they differ from 1) what you want and 2) what Windows is reporting? I've seen some interference from "over-configured" graphics adapter drivers so that might be worth looking at -- later ATI Catalyst drivers allow you to reset the driver settings to their factory defaults.
I returned the Samsung 2233RZ to newegg. I am now using an old Dell CRT E773c Dell E773c - display - CRT - 17" - CRT Monitors - CNET Archive I am attempting to hook it to my gaming lenovo laptop which has an ATI cart 5730 HD 1GB. When I open MonInfo it reads this
Monitor
Model name............... DELL E773c
Windows description...... Generic PnP Monitor
Manufacturer............. Dell
Plug and Play ID......... DELD005
Serial number............ 6418037O30DW
Manufacture date......... 2003, ISO week 30
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.000 (0.7V p-p)
Sync input support....... Separate
Display type............. RGB color
Screen size.............. 320 x 240 mm (15.7 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.631 - Ry 0.328
Green chromaticity....... Gx 0.275 - Gy 0.600
Blue chromaticity........ Bx 0.143 - By 0.057
White point (default).... Wx 0.283 - Wy 0.298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-70kHz
Vertical scan range...... 50-160Hz
Video bandwidth.......... 110MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1024x768p at 75Hz
Modeline............... "1024x768" 78.750 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 75Hz - VESA
640 x 480p at 85Hz - VESA STD
800 x 600p at 85Hz - VESA STD
1024 x 768p at 100Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
Report information
Date generated........... 1/2/2011
Software revision........ 2.52.0.857
Data source.............. Registry
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,10,AC,05,D0,57,44,30,33,1E,0D,01,03,68,20,18,78,2E,8A,A9,A1,54,46,99,24,
0E,48,4C,A4,42,00,31,59,45,59,61,68,81,80,71,4F,01,01,01,01,01,01,C3,1E,00,20,41,00,20,30,10,60,
13,00,36,E6,10,00,00,1E,00,00,00,FF,00,36,34,31,38,30,33,37,4F,33,30,44,57,0A,00,00,00,FC,00,44,
45,4C,4C,20,45,37,37,33,63,0A,20,20,00,00,00,FD,00,32,A0,1E,46,0B,00,0A,20,20,20,20,20,20,00,9D
Your monitor reports supporting 1024 x 768p at 100Hz - VESA STD so you shouldn't need to use this tutorial at all if you want to display that timing. You'll need to open advanced settings from screen resolution control panel and choose from the "list all modes" on the adapter tab.
thats what i dont understand, when i do that it says out of range/frequency.
