Force DVI/HDMI resolutions and refresh rates
Page 25 of 33 FirstFirst ... 152324252627 ... LastLast
  1. Posts : 2
    Ubuntu 10.10 / Seven / MacOS X
       #240
    baarod said:
    Bozy said:
    Thank you very much for your solution!!
    Thanks to you, my Philips 109s can run again in 2010!
    What, they didn't support EDID?
    No, the 109s has an EDID with a minimum frequency of 75Hz on Windows 7.
    But for a resolution of 1600x1200, the screen can only go up to 70Hz.
    At 75Hz, the image displayed on the screen but is brown and blackened edges.
    Again thank you for using your tutorial!
  2. Posts : 8
    Windows 7 64bit
       #241
    Help
    Hi, I just got the Samsung LCD SynyMaster 2233RZ 120hz. The monitor came with a DVI-DL link but my laptop that I want to connect it to does not support DVI. I went ahead and bought a DVI-D to HDMI Cable. It won't let me surpass 60hz when I try to change the refresh rate. I tried following this guide but it seems so confusing. Can anyone help?
  3. Posts : 1,519
    El Capitan / Windows 10
       #242
    That limitation is entirely imposed by your adapter. You should be able to override any mangled EDID information and choose the resolution and refresh rate you desire by following the instructions in this tutorial.
  4. Posts : 8
    Windows 7 64bit
       #243
    Is there anyway to restore default settings? When I tried using this guide I was careless and experimented with the wrong things.
  5. Posts : 1,519
       #244
    Press F8 while rebooting and select low res or 640x480 mode. Then uninstall the custom monitor driver using device manager.
  6. Posts : 8
    Windows 7 64bit
       #245
    Change to CRT
    So I went ahead and plugged my old CRT in that i KNOW gets 100hz on 1024x768. I ran through all the directions correctly and when I restart it shows in drop-down menu that I have the ability to put it to a 100hz. But once I click apply my screen says out of range/frequency? I know for a fact it has something to do with my computer not the monitor itself. Any ideas?
  7. Posts : 1,519
       #246
    Without using the modified monitor driver you created as a product of running through the tutorial, what were the capabilities reported by the monitor? From you recent posts it appears that there are at least two monitors in question here, an "old" CRT, a SyncMaster 2233RZ and maybe something else. The SyncMaster supports only DVI but a true DVI to HDMI adapter cable should work just fine supposing that it is straight wired owing to the fact that the digital video signal carried by HDMI is identical to that carried by DVI-D. I'd verify the SyncMaster's performance on a computer with native DVI and make a technical inquiry about your adapter cable. What does MonInfo claim are your SyncMaster's capabilities and how do they differ from 1) what you want and 2) what Windows is reporting? I've seen some interference from "over-configured" graphics adapter drivers so that might be worth looking at -- later ATI Catalyst drivers allow you to reset the driver settings to their factory defaults.
  8. Posts : 8
    Windows 7 64bit
       #247
    I returned the Samsung 2233RZ to newegg. I am now using an old Dell CRT E773c Dell E773c - display - CRT - 17" - CRT Monitors - CNET Archive I am attempting to hook it to my gaming lenovo laptop which has an ATI cart 5730 HD 1GB. When I open MonInfo it reads this
    Monitor
    Model name............... DELL E773c
    Windows description...... Generic PnP Monitor
    Manufacturer............. Dell
    Plug and Play ID......... DELD005
    Serial number............ 6418037O30DW
    Manufacture date......... 2003, ISO week 30
    EDID revision............ 1.3
    Input signal type........ Analog 0.700,0.000 (0.7V p-p)
    Sync input support....... Separate
    Display type............. RGB color
    Screen size.............. 320 x 240 mm (15.7 in)
    Power management......... Active off/sleep
    Extension blocs.......... None
    DDC/CI................... n/a
    Color characteristics
    Default color space...... sRGB
    Display gamma............ 2.20
    Red chromaticity......... Rx 0.631 - Ry 0.328
    Green chromaticity....... Gx 0.275 - Gy 0.600
    Blue chromaticity........ Bx 0.143 - By 0.057
    White point (default).... Wx 0.283 - Wy 0.298
    Additional descriptors... None
    Timing characteristics
    Horizontal scan range.... 30-70kHz
    Vertical scan range...... 50-160Hz
    Video bandwidth.......... 110MHz
    CVT standard............. Not supported
    GTF standard............. Not supported
    Preferred timing......... Yes
    Native/preferred timing.. 1024x768p at 75Hz
    Modeline............... "1024x768" 78.750 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
    Standard timings supported
    720 x 400p at 70Hz - IBM VGA
    640 x 480p at 60Hz - IBM VGA
    640 x 480p at 75Hz - VESA
    800 x 600p at 75Hz - VESA
    1024 x 768p at 75Hz - VESA
    640 x 480p at 85Hz - VESA STD
    800 x 600p at 85Hz - VESA STD
    1024 x 768p at 100Hz - VESA STD
    1280 x 1024p at 60Hz - VESA STD
    1152 x 864p at 75Hz - VESA STD
    Report information
    Date generated........... 1/2/2011
    Software revision........ 2.52.0.857
    Data source.............. Registry
    Operating system......... 6.1.7600.2
    Raw data
    00,FF,FF,FF,FF,FF,FF,00,10,AC,05,D0,57,44,30,33,1E,0D,01,03,68,20,18,78,2E,8A,A9,A1,54,46,99,24,
    0E,48,4C,A4,42,00,31,59,45,59,61,68,81,80,71,4F,01,01,01,01,01,01,C3,1E,00,20,41,00,20,30,10,60,
    13,00,36,E6,10,00,00,1E,00,00,00,FF,00,36,34,31,38,30,33,37,4F,33,30,44,57,0A,00,00,00,FC,00,44,
    45,4C,4C,20,45,37,37,33,63,0A,20,20,00,00,00,FD,00,32,A0,1E,46,0B,00,0A,20,20,20,20,20,20,00,9D
  9. Posts : 1,519
       #248
    Your monitor reports supporting 1024 x 768p at 100Hz - VESA STD so you shouldn't need to use this tutorial at all if you want to display that timing. You'll need to open advanced settings from screen resolution control panel and choose from the "list all modes" on the adapter tab.
  10. Posts : 8
    Windows 7 64bit
       #249
    thats what i dont understand, when i do that it says out of range/frequency.
