#250
There's been some confusion over the fact that Windows 7 now uses Electronic Industries Alliance (EIA-861B) TV-compatible timings. This explains it from the NTSC standpoint: Screen refresh rate in Windows 7 does not apply the user selected settings on monitors & TVs (that report specific TV compatible timings)
Even though the KB does not go into it, PAL and SECAM rates are also affected so your 100Hz is actually getting set to 100/1001*100Hz or ~99.9Hz by Windows 7 and the driver. See if you can set a custom rate of 100.1 or see this if you're an nVidia guy:
Advanced Timings
Here's a good explanation of where these weird timings came from: Frame+Rate+Follies.pdf
