tried to set 150Hz on 640x480, 800x600, and 1024x768 as always on VISTA. Reported test successful by NVIDIA Control Panel, but during 15 seconds until I click yes or no, I press setting button on Monitor it displayed 120Hz, click yes to add them anyway and they are all marked 120Hz at custom resolution list.
Still cannot use 150Hz or higher at all. My CRT monitor is Sony CPD-G520P.
The only thing I altered in EDID by Phoneix EDID Designer is on tab Standard Timings, change H. Active pixels of ID 5,6,7,8 to 640, 800, 1024, 1280 with all refrsh value to 120.
monitor.inf CRT Driver
; INF file generated by Monitor Asset Manager, 8/3/2009
; Copyright (c) EnTech Taiwan, 1995-2009.
; Internet: http://www.entechtaiwan.com
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=8/3/2009, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\SNY00B1
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\SNY00B1
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x4D,0xD9,0xB1,0x00,0x01,0x01,0x01,0x01,0x17,0x0D,0x01,0x03,0x0E,0x28,0x1E,0x96,0x2B,0x0C,0xC9,0xA0,0x57,0x47,0x9B,0x27,0x12,0x48,0x4C,0xFF,0xFF,0x80,0xE1,0x4F,0xD1,0x59,0xA9,0x59,0x81,0x99,0x31,0x7C,0x45,0x7C,0x61,0x7C,0x81,0x7C,0x86,0x3D,0x00,0xC0,0x51,0x00,0x30,0x40,0x40,0xA0,0x13,0x00,0x84,0x23,0x11,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00,0x30,0xAA,0x1E,0x82,0x25,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x43,0x50,0x44,0x2D,0x47,0x35,0x32,0x30,0x50,0x0A,0x20,0x20,0x20,0x00,0x00,0x00,0xFF,0x00,0x38,0x30,0x32,0x36,0x37,0x36,0x37,0x0A,0x20,0x20,0x20,0x20,0x20,0x00,0x0F
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,1
[MODE1]
HKR,,MaxResolution,,"1280,1024"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\1280,1024",Mode1,,"30.0-130.0,48.0-170.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="Sony CPD-G520P (EDID Override)"
VENDOR="Sony"
EDID open with Notepad
EDID BYTES:
0x 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 | 00 FF FF FF FF FF FF 00 4D D9 B1 00 01 01 01 01
10 | 17 0D 01 03 0E 28 1E 96 2B 0C C9 A0 57 47 9B 27
20 | 12 48 4C FF FF 80 E1 4F D1 59 A9 59 81 99 31 7C
30 | 45 7C 61 7C 81 7C 86 3D 00 C0 51 00 30 40 40 A0
40 | 13 00 84 23 11 00 00 1E 00 00 00 FD 00 30 AA 1E
50 | 82 25 00 0A 20 20 20 20 20 20 00 00 00 FC 00 43
60 | 50 44 2D 47 35 32 30 50 0A 20 20 20 00 00 00 FF
70 | 00 38 30 32 36 37 36 37 0A 20 20 20 20 20 00 0F
Asset Information in MonInfo
Monitor
Model name............... CPD-G520P
Manufacturer............. Sony
Plug and Play ID......... SNY00B1
Serial number............ 8026767
Manufacture date......... 2003, ISO week 23
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.300 (1.0V p-p)
Sync input support....... Separate, Composite, Sync-on-green
Display type............. RGB color
Screen size.............. 400 x 300 mm (19.7 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.50
Red chromaticity......... Rx 0.625 - Ry 0.340
Green chromaticity....... Gx 0.280 - Gy 0.605
Blue chromaticity........ Bx 0.155 - By 0.070
White point (default).... Wx 0.283 - Wy 0.298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-130kHz
Vertical scan range...... 48-170Hz
Video bandwidth.......... 370MHz
CVT standard............. Not supported
GTF standard............. Supported
Preferred timing......... Yes
Native/preferred timing.. 1280x1024p at 85Hz (4:3)
Modeline............... "1280x1024" 157.500 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
720 x 400p at 88Hz - IBM XGA2
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768i at 87Hz - IBM
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
2048 x 1536p at 75Hz - VESA STD
1920 x 1440p at 85Hz - VESA STD
1600 x 1200p at 85Hz - VESA STD
1280 x 1024p at 85Hz - VESA STD
640 x 480p at 120Hz - VESA STD
800 x 600p at 120Hz - VESA STD
1024 x 768p at 120Hz - VESA STD
1280 x 960p at 120Hz - VESA STD
Report information
Date generated........... 8/4/2009
Software revision........ 2.30.0.797
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4D,D9,B1,00,01,01,01,01,17,0D,01,03,0E,28,1E,96,2B,0C,C9,A0,57,47,9B,27,
12,48,4C,FF,FF,80,E1,4F,D1,59,A9,59,81,99,31,7C,45,7C,61,7C,81,7C,86,3D,00,C0,51,00,30,40,40,A0,
13,00,84,23,11,00,00,1E,00,00,00,FD,00,30,AA,1E,82,25,00,0A,20,20,20,20,20,20,00,00,00,FC,00,43,
50,44,2D,47,35,32,30,50,0A,20,20,20,00,00,00,FF,00,38,30,32,36,37,36,37,0A,20,20,20,20,20,00,0F
