Monitor
Model name............... Elgato
Manufacturer............. EGA
Plug and Play ID......... EGA0001
Serial number............ n/a
Manufacture date......... 2012, ISO week 42
Filter driver............ None
EDID revision............ 1.4
Input signal type........ Digital
Color bit depth.......... 10 bits per primary color
Color encoding formats... RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
Aspect ratio (portrait).. 1:1.01
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.340
Green chromaticity....... Gx 0.300 - Gy 0.690
Blue chromaticity........ Bx 0.138 - By 0.038
White point (default).... Wx 0.282 - Wy 0.297
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 25-70kHz
Vertical scan range...... 23-61Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
1280 x 720p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 4
Detailed timing #1....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #2....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #3....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #4....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1) [Native]
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 30Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16-bit at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
Report information
Date generated........... 26/11/2012
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0011
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,14,E1,01,00,00,00,00,00,2A,16,01,04,B0,00,02,78,1A,CF,74,A3,57,4C,B0,23,
09,48,4C,00,00,00,81,C0,D1,C0,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,C4,8E,21,00,00,1E,00,00,00,18,00,1C,16,20,58,2C,25,00,C4,8E,21,00,00,9E,00,00,00,FC,00,45,
6C,67,61,74,6F,0A,20,20,20,20,20,20,00,00,00,FD,00,17,3D,19,46,0F,00,0A,20,20,20,20,20,20,01,9C,
02,03,26,F4,51,85,04,03,02,12,13,94,16,07,06,11,15,A1,A2,27,1F,10,23,09,07,01,83,01,00,00,67,03,
0C,00,10,00,20,2D,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,C4,8E,21,00,00,98,8C,0A,D0,8A,20,E0,2D,10,
10,3E,96,00,C4,8E,21,00,00,19,01,1D,00,72,51,D0,1E,20,6E,28,55,00,C4,8E,21,00,00,1F,01,1D,80,18,
71,1C,16,20,58,2C,25,00,C4,8E,21,00,00,9E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,0F
