#180
Aw, I'm sorry to hear that it got you so much grief from other users! I have nothing but gratitude, as this is exactly what I was looking for. I'm so glad you posted it!
Your fix is very clever, in my opinion. I'd considered picking a different monitor driver, but nothing in the list of Microsoft-provided drivers seemed helpful. I like how your method gets me a new driver that's specifically tailored for my display (since it is based off the display's original EDID). You managed to turn a very complicated job into a relatively simple set of instructions.
I have to give Microsoft a wag of my finger for being so strict about resolution and refresh rate selection. There's a checkbox in the control panel for hiding modes that are not supported, but it doesn't seem to allow anything more when you uncheck it! And do they really think a display that takes 75Hz won't take 60Hz? If their solution panned out perfectly, and nobody ever got out-of-scan errors, I might forgive them -- but my friend had problems with an old LCD because it was reporting 56Hz support that it didn't actually have. (Hey, your fix might help him too!)
