Theme - Specify Default Theme to Load for New Users
  1. Posts : 1
    Windows 7 Pro/Ultimate x64
    erco61,
    Did you figure this problem out? I was able to set the default theme for all new users using the group policy editor in 64 bit windows 7 as shown above. Didn't bother with the registry keys. Just copied my theme to the themes directory and set the path in GPO to C:\Windows\Resources\Themes\mytheme.theme.
    You still need to follow post #6 for the desktop shortcuts. I don't know if you put IE favorites into C:\Users\Default\Favorites if they will be copied to new profiles or not. If not, you can load the default user hive and add a RunOnce entry (i.e. newUser.bat) to copy the shortcuts from a directory (i.e. C:\bin\favorites) to C:\Users\%username%\Favorites. That should automate that process of copying the shortcuts to newly created profiles the first time the user logs on.
    Hope that helps.
  2. Posts : 17
    Windows
    Yes and No.
    I did get the default theme policy working after a fresh OS install.
    But, since the theme doesn't save all aspects of the user's environment as desired, I have worked around the problem by replacing the c:\Users\Default User folder. Now all aspects of the user's environment are configured by default for a new user.
  3. Posts : 2
    Windows 7 Professional x64
       #12
  4. Posts : 72,059
    Thank you Jay. :)
  5. Posts : 1
    Windows 7 64-bit Enterprise
       #14
    Thank you for the excellent tutorial.
  6. Posts : 1
    Windows 8.1 pro 64bit
       #15
    No .theme
    when i try to set this, i find my theme file but it is not a .theme
    it is a .deskthemepack
    what do i do?
  7. Posts : 72,059
       #16
    Hello Corriganc, and welcome to Seven Forums. :)
    For Windows 8 issues, it would be best to post at out sister site www.eightforums.com instead.
    Windows 8 uses a desktop theme pack .deskthemepack instead of a .themepack file in Windows 7. You would need to save your theme using the method in step 7 below to have it saved as a .theme file instead. :)
    Theme - Save in Windows 8
  8. Posts : 2
    Hello all,
    I was able to fix this issue I was having on a 64 bit (x64) version of Windows 7 by editing the registry since the GPO setting nor the Hotfix did anything for me.
    Opening the registry with regedit, in HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Themes
    Change the data entry for "InstallTheme" to the location of which your .theme file is located. After restarting, this worked perfectly!
  9. Posts : 72,059
       #18
    Hello DarkOnyx, and welcome to Seven Forums.
    Thank you for your feedback.
    The registry location in Option Two didn't work for you to use the specified theme when creating a new user account?
  10. Posts : 2
    Hey Brink,
    Sorry, it didn't work for me. I tried Option #2 again just to make sure and still was not able to make it work.
