Shortcut Extension - Remove or Restore
    How to Remove or Restore the "Shortcut" Name Extension in Windows 7 and Windows 8
    This tutorial will show you how to remove or restore the "- Shortcut" extension from a shortcut file name when any new shortcut is created in Windows 7 and Windows 8.
       Warning
    This will only remove or restore the "shortcut" name extension for newly created shortcuts afterwards, not for previously existing shortcuts.
    EXAMPLE: A New Folder with the New Folder Shortcut
    NOTE: When you create a new shortcut or New Folder, by default, it will add the Shortcut extenstion to the file name. The last icon is an example of when you create a shortcut of New Folder with the Shortcut extension set to be removed.
    OPTION ONE
    To Add or Remove "Shortcut" Name Extension using a REG File
    1. To Remove the Shortcut Extension
    A) Click/tap on the Download button below to download the file below, and go to step 3 below.
    Remove_Shortcut_Extension.reg
    2. To Restore the Shortcut Extension
    Restore_Shortcut_Extension.reg
    4. Double click/tap on the extracted .reg file to merge it.
    5. Click/tap on Run, Yes (UAC), Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    To Add or Remove "Shortcut" Name Extension in Registry Editor
    1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
    2. If prompted by UAC, click/tap on Yes.
    3. In the registry, go to: (See screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
    4. In the right pane of Explorer, double click/tap on link to modify it. (See screenshot above)
    5. To Remove the Shortcut Extension
    A) Change the value to 00 00 00 00 and click/tap on OK, and go to step 7 below. (See screenshot below)
    NOTE: To change the value, press the Delete (Del) key once and type 00.
    B) Go to step 7.
    6. To Restore the Shortcut Extension
    A) Change the value to 1E 00 00 00 and click/tap on OK, and go to step 7 below. (See screenshots below)
    NOTE: To change the value, press the Delete (Del) key once and type 1E.
    7. Close regedit.
    8. Log off and log on, or restart the computer to apply changes.
  1. Posts : 4,925
    Windows 7 Professional 64-bit
    beta 7000 doesnt seem to add "shortcut".
  2. Posts : 4,282
    Are you sure!!
  3. Posts : 72,037
    Hi Swarfega,
    I must agree with Mr GRiM. The Windows 7 Beta (7000 build) show the "Shortcut" prefix for me still when I create one from a New Folder on the desktop.
  4. Posts : 12,364
    8 Pro x64
    Is there an easy way to remove the shortcut overlay? Besides third party apps, I never found a "windows" way to remove them.
  5. Posts : 54
    Win7 x64 Ultimate RTM
    Closest I came to that was this reg hack with a blank .ico. Works for me as it did in Vista. Read the readme so you know which to use (for 32 or 64 bits). Got it on Neowin a long time ago.
  6. Posts : 72,037
    Smarty,
    The only safe and easy way I know is with a 3rd party app as well. The other methods usually messed up the shortcut icons. I have not tried this in Windows 7 yet, but I see no reason why it wouldn't work though.
    Shortcut Arrow - Vista Forums
    VegasDen,
    THe link you link you posted comes back as invalid.
  7. Posts : 4,282
  8. Posts : 72,037
    Thank you Mr GRiM.
  9. Posts : 83
    Windows 7 RC Build 7100 x86 / Windows Vista SP2
    does this just work for folders? i still have the arrow overlay on my shortcuts i have sent to the desktop.
