Shortcut Extension - Remove or Restore
Page 2 of 2 FirstFirst 12
  1. Posts : 72,051
    Hello System001,
    I think you're wanting this tutorial instead.
    https://www.sevenforums.com/tutorials...e-restore.html
  2. Posts : 83
    Windows 7 RC Build 7100 x86 / Windows Vista SP2
    shortcut arrow is gone
    system001 said:
    does this just work for folders? i still have the arrow overlay on my shortcuts i have sent to the desktop.
    i lied. i guess it just took a couple of restarts for some reason. thanks for the download. i have always disliked the arrow overlay. i do not need an arrow to tell me the icon is a shortcut. thanks again.
  3. Posts : 72,051
       #12
    LOL, you're welcome System001. :)
  4. Posts : 1
    windows 7
    Mr GRiM said:
    Here you go Shawn, seemed to work for me. Attachment 2839
    Thanks much! Worked perfectly in Windows 7.
  5. Posts : 2
    Windows 7 HP 64bit
       #14
    Help, after applying shortcut remover in Windows 7 the shortcut overlay displays a small black square where the shortcut arrow was previously. How do I fix this? Thanks!
  6. Posts : 72,051
       #15
    Hello Kelly, and welcome to Seven Forums.
    You should be able to restore the default shortcut arrow icon overlay using the tutorial below. If you wanted to removed the arrow, then you can use the same tutorial to remove it after restoring the default settings to fix it.
  7. Posts : 2
    Windows 7 HP 64bit
       #16
    Thanks for the help. I used the tutorial and after a couple of reboots the icons are back to normal.
  8. Posts : 72,051
       #17
    You're welcome Kelly. I'm happy to hear that you got it sorted. :)
  9. Posts : 38
    Perfect! Thanks a lot!
