#40
OK, the issue is still there. Randomly it decided to clear my list of pinned jump list items. GREAT! :) It turned out it's not a problem with my system because I did a clean reinstalled of Win7x64 Ultimate. Setup everything as I am used to and after a while, the jump list pinned items are all cleared again. So it's either a bug in the OS or some of my tweaks. I'd assume it is the latter but I can't quite put my finger on it. A wild guess would be - can it be something with the System properties - Advanced (tab) - Performance settings - Visual effects? From the visual effects all I use is the 'Show thumbnails instead of icons' and 'Smooth edges on screen fonts'. All else is off cos there's no need for it. But still ... could it be any of those settings that I've turned off there? Difficult to do the trial and error in this case since the error occurs only like once in ... whenever it feels like, no pattern at all.
Looking for help troubleshooting this.
PS - no ccleaner, no nothing, not using any 3rd party or any scheduled task to schedule or clean or run anything. Isn't there a log somewhere to check where and what ran when?
