#40
Hello @Scoop, :)
Q1) You are only turning system protection off for the drive like in the tutorial linked below. The .reg files in the tutorial will completely disable system restore preventing you from being able to turn on/off system restore for any drive.
System Protection - Turn On or Off - Windows 7 Help Forums
There's nothing wrong with just turning off system restore, but if you wanted to make sure it stays off and disabled, then the .reg files will do that.
Q2) If system protection is turned on, then it's normal for Windows to automatically create a restore point before installing a Windows Update.
It's also not unusual for a Windows Update to reset some settings back to default.
