Hibernate - Enable or Disable
Page 2 of 12 FirstFirst 1234 ... LastLast
  1. Posts : 72,062
    Thank you Aaron and Limneos.
    I do not have it availale in my 7048 build either anymore. I placed a warning for now until the next version comes out to see if it returns or not.
  2. Posts : 18,404
    You're welcome Shawn and cheers on your 1900th post.
  3. Posts : 72,062
       #12
    Wow, adding up already.
  4. Posts : 14
    Windows Vista x64
    Thanks for the tip! I knew I deleted this file through the disk cleanup utility with the beta, but I couldn't figure it out in the RC.
  5. Posts : 72,062
       #14
    You're welcome x3haloed. :)
    Yeah, they removed this from Disk Cleanup recently from a few builds back. When turned off in Power Options, it now disables it automatically now. Much better.
  6. Posts : 2,036
    Windows 7 Professional x64
       #15
    I have turned off hibernate with method 2 through power options yet I still have a giant hiberfil.sys file. Why is this? Do I need to delete it or do both methods? I have never used hibernation and never plan to do so.
  7. Posts : 72,062
       #16
    Hi Nate,
    See if also under Allow hybrid sleep, setting Setting to Off removes the file. If not, then METHOD ONE should.
  8. Posts : 2,036
       #17
    Thanks Brink, I tried method 1 and it disappeared. I guess that's the easy way. Thanks. I'm down to about a 7GB Windows 7 installation that's blazing fast. haha
    I'm loving this SSD. I think you inspired me to get one. haha
    These things are so darn sweet!
  9. Posts : 72,062
       #18
    You're welcome Nate. Yeah, these SSd drives are pretty nice. I can't wait until I replace my older generation SSD with the newer and much faster generation. :)
  10. dek
    Windows 7 x64 sp1, XP x86 sp2
       #19
    I was looking for a way to delete the hibernation file since i dont use hibernation and i look at it as wasted space, and even after disabling and turning it off under the power plan the file did not get deleted until i used the powercfg -h off.
    cheers
