Hibernate - Enable or Disable
Page 12 of 12 FirstFirst ... 2101112
  1. Posts : 67
    Windows 10 Pro Insider Preview + WSL2
       #110
    Lenovo X200 laptop has fn+f12 combo for hibernation.
    I disabled hibernation (long time ago) but when I accidentally hit fn+f12 system got hibernated, after resuming value in registry changed from 0 to 1.
  2. Posts : 37
    Windows 7 home premium 32 bit
       #111
    What is the point of "Check your Power Options to make sure that the Critical battery action and Low battery action settings under Battery are not set to Hibernate. (see screenshot below)" while the screenshot shows that Critical battery action is hibernate?
    What happen if I disable hibernation and my laptop battery is very low?
  3. Posts : 67
       #112
    it's in post #103
