How to Set Processor Affinity to an Application in Windows 7
Processor affinity or
CPU Pinning enables the binding and un-binding of a
process or
thread to a physical CPU or a range of CPUs, so that the process or thread in question will run only on the CPU or range of CPUs in question, rather than being able to run on any CPU
By default,
Vista and
Windows 7 runs an application on all available cores of the processor. If you have a multi-core processor, then this tutorial will show you how to set the
processor affinity for an application to control which core(s) of the processor the application will run on.
If the application and CPU supports
Symmetric Multiprocessing (SMP) or
HyperThreading (HT), then Windows will automatically adjust the application's usage of each processor core for the best performance. You will not gain much, if anything, from manually changing the processor affinity for these type of applications.
If you have more then one processor intensive applications running, then you could improve their performance by setting the processor affinity of their processes to run on a different core(s). This way they are not competing for the resources of the same core(s).
It is NOT recommended to change the processor affinity for system processes. Doing so could reduce their performance or slow the system down.
The affinity changes you make to the current instance of an application or process are only temporary and not set permanently. Once you close the application or restart your system, the processor affinity of the application will automatically return back to the default of running on all available CPU cores.
OPTION ONE
To Set CPU Affinity of Process in Task Manager
1. Open the application that you want to change the
processor affinity of, and do
step 2 or 3 below.
2. If the Application Does Not "Run as administrator"
A) Right click on a empty space on the taskbar, click on Task Manager, and go to step 4 below.
NOTE: You can also press CTRL+SHIFT+ESC to open Task Manager.
3. If the Application Does "Run as administrator" (Elevated)
A) Click on the
Processes tab in Task Manager, then click on the
Show processes from all users button. (see screenshot below)
B) If prompted by
UAC, then click on
Yes (if administrator) or enter the
administrator's password (if standard user).
C) Continue on to
step 4.
4. In Task Manager, click on the
Applications tab, right click on the application from step 1, and click on
Go to Process. (see screenshot below)
5. In the
Processes tab, right click on the application's process, then click on
Set Affinity. (see screenshot below)
NOTE: If Set Affinity is grayed out, then it means that the process cannot have the processor affinity set for.
6. Check (allow) or Uncheck (not allow) one or more CPU cores that you want to be allowed or not allowed to run the application on, then click on
OK. (see screenshot below)
NOTE: Only the number of cores in your processor(s) will be available to set affinity to. CPU-0 = Core 1, CPU-1 = Core 2, etc...
7. Repeat for any other applications that you wish to change the processor affinity of.
8. When finished, close Task Manager.
OPTION TWO
To Run a Program with a Set CPU Affinity in Command Prompt
1. This step will show you how many CPU cores you have, and how to figure the
hex value to use at
step 3 below for the CPU(s) you want to run the application on.
NOTE: If you should need any assistance with this step, then please feel free to post. I'll be happy to help.
A) Open
Task Manager (CTRL+Shift+ESC) in more details view, click on the
Processes tab, right click on any process in the
Image Name column, and click on
Set affinity. (see screenshot below)
NOTE: This will show you how many CPU cores you have. I have
12 CPU cores numbered from
0 to 11.
B) For how many CPU cores you have will also be how long the binary number will be. Since I have
12 CPU cores, the binary number will be 12 zeros
000000000000. Each zero in the binary number represents a CPU core number from right to left. In my case with 12 CPU cores, the
far right 0 in the binary number will be for
CPU 0, and the
far left 0 will be for
CPU 11. (see screenshot below)
C) For each CPU number you want to run the application on, replace
0 (off) with
1 (on) in the binary number for the CPU numbers.
For example, if I wanted to run the application only on
CPU 0, then my binary number would be changed to
000000000001. To run the application on
CPU 0 and
CPU 3, I would use
000000001001. (see screenshot below)
D) Go the website below, and type your
binary number from step 1C above into the
Binary field. This will convert the binary number to a
hexadecimal (hex) that you will need to use at
step 3 below.
For example, with my
000000000001 binary number, I get a
hex value of
2. Open a
command prompt.
3. In the command prompt, type the command below into the location area, and click on the
Next button. (see screenshot below)
cmd.exe /c start "Program Name" /affinity # "Full path of application file"
For example: I would type this command below exactly if I wanted to create a shortcut to run
Process Monitor on only
CPU 0 (step 1), and it's .exe file is located at "
E:\Programs\Process Monitor 3.05\Procmon.exe".
(For only on CPU 0)
cmd.exe /c start "Process Monitor" /affinity 1 "E:\Programs\Process Monitor 3.05\Procmon.exe"
(For on CPU 0 and CPU 3)
cmd.exe /c start "Process Monitor" /affinity 9 "E:\Programs\Process Monitor 3.05\Procmon.exe"
Substitute Program Name in the command with the actual program's name within quotes.
Substitute # in the command for the affinity # with the hex value (ex: 1) from step 1D above.
Substitute Full path of application file in the command with the full path of the file within quotes.
