Aero Peek - Turn On or Off
Page 5 of 11 FirstFirst ... 34567 ... LastLast
  1. Posts : 18
    win7
       #40
    My problem with AeroPeak turned out to be caused by a program called TewakWin7 or something like that that when you pushed "optimize", it did something to kill aero peak etc.
  2. Posts : 72,051
       #41
    Xgman,
    I'm happy to hear that you found out what the culprit was. Thank you for posting back with this. Were you able to undo it?
  3. Posts : 805
    XP Pro SP3 x86/Vista SP2 x64/Win7 x64 Triple-boot
       #42
    Brink.. trying to download the 'Enabled_Aero_Peek.zip' gives a 404 error to me, It's not a problem for me because I can just alter the value of the 'disable..' one but others may require it. Just letting you know.
    Thanks for the tuto btw. :)
  4. Posts : 72,051
       #43
    Thank you Sean. It has been fixed. :)
  5. Posts : 620
    7264x64/7260x86
       #44
    Can you remove the button altogether from the taskbar?
  6. Posts : 72,051
       #45
    Hello Copernicus,
    Sorry, but no.
  7. Posts : 1
    vista
       #46
  8. Posts : 18,404
    The downloads work for me with IE or Firefox.
  9. Posts : 72,051
       #48
    Hello Porum, and welcome to Seven Forums.
    They seem to work fine for me as well. Do you have any security type of add-ons or programs installed that may block the download?
  10. Posts : 805
       #49
    That's spooky, He's just copied my earlier post word for word.
