#40
My problem with AeroPeak turned out to be caused by a program called TewakWin7 or something like that that when you pushed "optimize", it did something to kill aero peak etc.
Xgman,
I'm happy to hear that you found out what the culprit was. Thank you for posting back with this. Were you able to undo it?
Brink.. trying to download the 'Enabled_Aero_Peek.zip' gives a 404 error to me, It's not a problem for me because I can just alter the value of the 'disable..' one but others may require it. Just letting you know.
Thanks for the tuto btw. :)
Can you remove the button altogether from the taskbar?
That's spooky, He's just copied my earlier post word for word.
