Processor Affinity - Add Set Affinity to Context Menu
Page 3 of 3 FirstFirst 123
  1. Posts : 72,062
       #20
    Great news.
  2. Posts : 5
    Windows 7/10 64 Bits
       #21
    Hello, I have not been able until now. I'm going to put here the content of reg archive that at least to me it works. It's made for 4 cores, but it haven't all combinations, only these one:
    - 4 cores (0,1,2,3)
    - 3 cores (1,2,3)
    - 3 cores (1,2,3)
    - 2 cores (0,1)
    - 2 cores (2,3)
    - 1 core (0)
    - 1 core (1)
    - 1 core (2)
    - 1 core (3)
    The reg file is this one:
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad]
    "Icon"="%SystemRoot%\\System32\\shell32.dll,43"
    "MUIVerb"="Ejecutar con afinidad de ..."
    "SubCommands"=""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell]
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\1 Nº núcleos = 4]
    @="4 núcleos (el 0, 1, 2 y 3)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\1 Nº núcleos = 4\command]
    @="cmd /c start "Afinidad CPU" /affinity 0F "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\2 Nº núcleos = 3]
    @="3 núcleos (el 0, 1 y 2)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\2 Nº núcleos = 3\command]
    @="cmd /c start "Afinidad CPU" /affinity 07 "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\3 Nº núcleos = 3]
    @="3 núcleos (el 1, 2 y 3)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\3 Nº núcleos = 3\command]
    @="cmd /c start "Afinidad CPU" /affinity 0E "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\4 Nº núcleos = 2]
    @="2 núcleos (el 0 y 1)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\4 Nº núcleos = 2\command]
    @="cmd /c start "Afinidad CPU" /affinity 03 "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\5 Nº núcleos = 2]
    @="2 núcleos (el 2 y 3)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\5 Nº núcleos = 2\command]
    @="cmd /c start "Afinidad CPU" /affinity 0C "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\6 Nº núcleos = 1]
    @="1 núcleo (el 0)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\6 Nº núcleos = 1\command]
    @="cmd /c start "Afinidad CPU" /affinity 01 "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\7 Nº núcleos = 1]
    @="1 núcleo (el 1)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\7 Nº núcleos = 1\command]
    @="cmd /c start "Afinidad CPU" /affinity 02 "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\8 Nº núcleos = 1]
    @="1 núcleo (el 2)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\8 Nº núcleos = 1\command]
    @="cmd /c start "Afinidad CPU" /affinity 04 "%1""
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\9 Nº núcleos = 1]
    @="1 núcleo (el 3)"
    [HKEY_CLASSES_ROOT\exefile\shell\3 Ejecutar con afinidad\shell\9 Nº núcleos = 1\command]
    @="cmd /c start "Afinidad CPU" /affinity 08 "%1""
    Obviously, the words in castilian (spanish) are not obligatory (I don't know if this word is correct), it's possible to change it for language you want. In the same way, where says Afinidad CPU we can write (I think) whatever you want.Greetings.
