Common File Dialog Box - Customize Places Bar
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. Posts : 72,051
       #30
    Hello rotorb,
    You ran into an odd little issue here. Normally, you would be able to use just MyComputerFolder. For some reason when you had the D: folder paths, MyComputerFolder stops working. However, if you use Shell:MyComputerFolder instead, it works. Odd, but it works this way when you wouldn't normally need to.
  2. Posts : 1
    windows 7 home premium 64bit
       #31
    Many thanks, Shawn.
    Crisp, clear, works!
    Keep up the good work.
    JS
  3. Posts : 72,051
       #32
    You're most welcome James, and welcome to Seven Forums. :)
  4. Posts : 11
    Windows 7 Professional x64
       #33
    I tried using MyComputerFolder and shell:MyComputerFolder and none of them works unfortunately.
    Desktop and shellesktop do not work either.
  5. Posts : 72,051
       #34
    Hello 5moufl, and welcome to Seven Forums.
    They seem to be working fine for me. Could you post screenshots showing the same below to see if it may reveal what the issue may be? :)
  6. Posts : 11
       #35
  7. Posts : 72,051
       #36
    This below worked for me. You might see how it does for you. Is P, D, and E all local internal drives?
  8. Posts : 11
       #37
    They all are local drives except for E:
    In fact I just noticed that I get the correct dialog box in some situations and the one I showed you in some others. But it was the same type of dialog window, wasn't it? (after all I get those custom links for Dropbox, D and E)
  9. Posts : 72,051
       #38
    May be something with the program. What are you using "Open" in for the ones that don't show all of them? I'll do some more experimenting with the same ones to see if I may be able to find a way for it to show with them as well.
  10. Posts : 11
       #39
    Brink said:
    May be something with the program. What are using "Open" in for the ones that don't show all of them? I'll do some more experimenting with the same ones to see if I may be able to find a way for it to show with them as well.
    I didn't understand that last message but the program where the dialog kinda works (without desktop or mycomputerfolder) is Album Art Optimizer - iAudiophile.net Forums this.
