Password Reset
Page 4 of 12 FirstFirst ... 23456 ... LastLast
  1. Posts : 1
    Windows 7 Professional x64
       #30
    Another way
    There is another way(very similar) to do this that does NOT involve the registry. I read the comment about the balance so a 12 year old won't try this on his/her parents. Do I have permission to post the alternate way, which is the method I use? I know for a fact my method works on Server 2008, but I'm sure your method will as well.
  2. Posts : 22,814
    W 7 64-bit Ultimate
       #31
    Start a new thread here.
  3. Posts : 1
    Windows 7 Ultimate x32
       #32
    I registered in this forum just for saying thanks to this article
    Thanks mat
  4. Posts : 22,814
    W 7 64-bit Ultimate
       #33
    Thanks mat
    Hello hmr007, welcome to Seven Forums!
    It's very nice to see that people are helped, thanks for the kind words my friend.
  5. Posts : 4
    Please help
    Hi, I have completed all the directions, but after the restart when the command prompt box comes up I cannot type anything. The cursor flashes in the box but nothing will type. Would the fact that I am on a laptop and changed the key layout to United Kingdom make any difference? Any help appreciated.
  6. Posts : 22,814
    W 7 64-bit Ultimate
       #35
    Hello Kezzer, welcome to Seven Forums!
    I haven't heard of this issue before, it may be that the lappy K/B is not 'active' until a certain point that I have no idea about; perhaps someone will have some input for you so keep checking back.
  7. Posts : 4
    Thanks for getting back
    The command prompt box has just disappeared now. Took the battery out and it restarted to normal log in screen. I'm on an HP DV7 if that helps, feel gutted to have fallen at the last hurdle of changing the password.
  8. Posts : 22,814
    W 7 64-bit Ultimate
       #37
    Have you had a look to see if the method of using System Restore to go back will work for you?
    Password Reset : Using System Restore in Windows 7
  9. Posts : 4
    It's my mum's brand new one, she had it on about 30mins, then logged out and couldn't get back on. She swears the password is right but Windows says it's wrong. Don't think there would have been a restore point created yet? We didn't make one manually.
  10. Posts : 22,814
    W 7 64-bit Ultimate
       #39
    What kind / who built it? Perhaps you can do a factory restore and start over from scratch.
