Password Reset
Page 2 of 12 FirstFirst 1234 ... LastLast
  1. Posts : 22,814
    W 7 64-bit Ultimate
    Jonathan_King said:
    Bare Foot Kid said:
    Thanks J_K, I tested it VB with both Windows 7 (about 4 different times) and Vista and on my rig with Windows 7; to be quite honest, it's really very easy to do. :)
    But hard enough it may discourage the 12 year old trying to hack into his parent's machine.
    There's that delicate balance...
    That's the only concern I had posting it but the positives out-weigh the negatives.
    Hannibal001 said:
    Wish I would have know this before. Learn something every day. THX to the Bare Foot Kid.
    Hello Hannibal001, thanks!
  2. Posts : 1,586
    Another one to keep! :)
  3. Posts : 22,814
    W 7 64-bit Ultimate
       #12
    Hello Beau, thanks! :)
  4. Posts : 2
    windows 7
    which method are you referring to when you say all encrypted messages will be lost? And what determines which messages are encrypted or not? Sorry, new to this computer world.
  5. Posts : 22,814
    W 7 64-bit Ultimate
       #14
    Hello taskforce403, welcome to Seven Forums!
    The method described in this tutorial, if you use this tutorial to reset a user account password all encrypted files be lost; you would have to have personally used encryption software to encrypt files, Windows does not encrypt any files by default, all system files will remain unchanged.
  6. Posts : 8
    good
  7. Posts : 22,814
    W 7 64-bit Ultimate
       #16
    Hello George Atanas, welcome to Seven Forums; I'm glad you find it useful, thanks for the feedback.
  8. Posts : 1
    windows server 2003
       #17
    i have ever experienced the problem of forgetting Windows password, my solved way is use the Windows Password Reset Kit 1.5.
  9. Posts : 26
    Windows 7 Ultimate 64 Bit
       #18
    Bookmarked (I'm 16) I can hack into the family computer! (I forgot password)
    Lol not really!
    Thanks,
    Kcmartz
    Sent from my Motorola Cliq
  10. Posts : 3,322
    Windows 8.1 Pro x64
       #19
    Just had to use this guide myself when trying to fix one of my Mum's friend's laptop. Works great.
