Windows 7: Fan Speed Controller - Build your Own
18 Oct 2010   #20
ZaLiTH
Win 10 x64 Pro x64 / Ubuntu 15.10 x64
Quote   Quote: Originally Posted by Silvion View Post
Hey thanks for the reply!
Yeah, i understand that. The resistor on the LED won't affect the potentiometer at all?
Or did you mean have a "Y" section? splits to resistor/led and to potentiometer?
To be on the safe side, you could connect the LED directly to the ground. So you'd have two lines going from the switch to the ground, such as:
/ = switch
o = potentiometer
- = LED
~ = resistor
* = fan
  +12v
 o    ~
(ground)
That way, the fan will only be connected to the potentiometer and the LEd will only be connected to the resistor, while both the resistor and potentiometer will be controlled simultaneously by the switch.
18 Oct 2010   #21
Silvion
Ah yeah, awesome suggestions. Thanks a lot,
I could have the 12v going to three lots of those, and another 12v to another 3..
Thanks for your input!
18 Oct 2010   #22
Lordbob75
I can make two seperate circuits to have two 12v inputs, no worries there..
Also, would you know where i went wrong with these calculations?
12 = 12(85.71/(Rr+85.71))
1 = 85.71/(Rr+85.71)
1(Rr+85.71) = 85.71
Rr + 85.71 = 85.71
Rr = 1???
My fan is drawing 0.14amps on a 12v line:/
I just realized that I defined Vf in 2 different ways.
You want Vf to be 5v in this equation. I will go back and clarify that.
And yes, you want a Y connector off the switch. The reason is that if you put the LED inline with the pot, you won't have enough to power the fan as the fan needs 12v, not 2v.
~Lordbob
18 Oct 2010   #23
Lordbob75
Quote   Quote: Originally Posted by ZaLiTH View Post
/ = switch
o = potentiometer
- = LED
~ = resistor
* = fan
  +12v
 o    ~
(ground)
Exactly.
~Lordbob
18 Oct 2010   #24
ZaLiTH
No problem.. :) I know it was written with a slightly different purpose in mind (switch for LEDs in the fan itself), but you might find the information in LordBob's other tutorial helpful in this quest: Lights - Add An On/Off Switch
18 Oct 2010   #25
ZaLiTH
Quote   Quote: Originally Posted by Lordbob75 View Post
Exactly.
~Lordbob
Lol.. I think I'm coming dangerously close to hijacking your thread here... Oops...
18 Oct 2010   #26
Lordbob75
Exactly.
~Lordbob
Don't worry about it.
I am reworking the equation to be SOLVED for Rr, so it will involve a lot less algebra for those reading.
However, I keep getting 2 completely different resists, so I am still working on that.
~Lordbob
18 Oct 2010   #27
Lordbob75
1(Rr+85.71) = 85.71
Rr + 85.71 = 85.71
Rr = 1???
Here is the new equation:
Rr = ((Vs*Rf)/Vf)-Rf
Rr = ((12*85.7)/5)-85.7
Rr = 119.98 Ohms, assuming you want a 5v minumum.
Sorry about the confusion.
~Lordbob
18 Oct 2010   #28
Silvion
~Lordbob
Ah thanks for clearing that up, so i need a potentionmeter's around 120 ohms? (can't go below 120, but can go higher? Just means that they won't go as slow when spinning?)
So fans will run at a minimum of 5v, max of 12v?
18 Oct 2010   #29
Lordbob75
~Lordbob
It is variable.
I have found that the fan needs about 10v minimum to start, but will keep running down to around 3 or 4 volts.
Now, if you INCREASE the size on the potentiometer (i.e. 150 ohms), then the fan will spin slower. If you decrease the pot (i.e.100 ohms), then it will spin faster.
It is up to how slow you want the fan to go. I picked 5v as a low because that is the lowest it is really rated at, and it just turned off after that.
~Lordbob
Ethernet Controller Link Speed is locked at 10 Mbps.
My network card is a Realtek PCIe FE Family Controller. I don't know what caused this problem but my Realtek driver is up-to-date, and previously it was a link speed of 100 Mbps. http://i.imgur.com/oodGbxx.jpg But now for some reason it suddenly dropped to a link speed of 10 Mbps and I've tried a...
Network & Sharing
SATA AHCI Controller, IDE DVD RW slow speed
I have 2 IDE DVD drives (TEAC DV-W516D DVD/CD ReWriter, and TSSTcorp DVD-ROM SH-D162C DVD/CD Reader). Teac is capable of 16X DVD writting. My motherboard Gigabyte Z77-D3H has only SATA II/III slots. So I connected each IDE optical drive to motherboard's SATA II slot(s) using IDE to SATA I adapters...
Hardware & Devices
My Antec 300 case came with 2 case fans that have a switch H M L switch on them... and it is kind of a pain in the ass to open the case to switch the fan speeds. I usually keep them on low for noise reduction, but during gaming or other heat intense work id like them to ramp up a bit to keep the...
Hardware & Devices
[Project] Fan Speed Controller
Alright! I finally succeeded in getting the first third of my fan controller completed. I thought I would post a picture of what it looks like right now: What do you all think? I have it plugged into my side fan for now, and have left it on full speed. The issues I have run into are:...
PC Custom Builds and Overclocking
Xbox 360 Controller Bug in Build 7068?
I have used my Xbox 360 wired controller with my PC for a while, on both XP and Vista prior to installing Windows 7 Betas. The first time I noticed this was with build 7068 x64, which is what I am currently using. If anybody else has a wired xbox 360, let me know if you can reproduce this. If I...
Gaming
Twitter Facebook
