Display Language - Change
  1. Posts : 28,845
    Win 8 Release candidate 8400
    punky said:
    well actually, I do not really know :S:S ...where can I see what version is it?
    start>search>type winver
  2. Posts : 11
    32 bit
    this is what I got from typing that:
    Microsoft Windows
    Version 6.1 (build 7601: Service Pack 1)
    Copyright (c) 2009 Microsoft Corporation. Alle Rechte vorbehalten.
    Das Betriebssystem Windows 7 Starter und die zugehorige Benutzeroberflache sind durch Marken- und andere rechtshangige bzw. bestehende gewerbliche Schutz- und urheberrechte in den vereingten Staaten und anderen Landern geschutzt
    Dieses Produkt ist unter den Microsoft-Softwarelizenbedingungen lizenziert fur: Saturn
  3. Posts : 72,057
       #12
    Hello Punky, and welcome to Seven Forums.
    Right above all that, you should see what edition you have instead like below. :)
  4. Posts : 11
    32 bit
    thnx for welcoming me....and I'm really sorry cuz right now I am feeling like an amateur LOL ... It's Windows 7 Starter :)
  5. Posts : 28,845
       #14
    Cant change it.
  6. Posts : 11
    32 bit
       #15
    do you know if there's a way I could install Windows XP in it ???
  7. Posts : 28,845
       #16
    You mean dual boot? Or replace win 7?
  8. Posts : 11
    32 bit
       #17
    I mean replacing it with XP
  9. Posts : 72,057
       #18
    Punky,
    Sure, you could boot from your Windows XP installation DVD, and start the installation process to format the HDD and install XP. However, you need to make sure that you have XP driver versions for all of your devices and have them downloaded and saved somewhere before doing so to install them after you done with installing XP.
  10. Posts : 11
    32 bit
       #19
    Cuz my dad tried this procedure yesterday but it did not work that's why I'm asking...
