Run Commands - Create
    How to Create Custom Run Commands
    Using the Run / Start Search command in Windows you can use certain pre-defined commands to open up applications like we open MSCONFIG etc.
    Here are the Steps
    1. Go to Start under Start Search type in Regedit and Hit Enter
       Warning
    Ensure to make a backup before you modify any Registry Entry
    2.Follow this Link for help in backing up Registry :- Registry - Backup and Restore
    3. Then go to
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths
    4. In the left panel, right click this App Paths key and choose New | Key and Type the Application name
    Note: Don't forget to type the extension as well
    For Example: CCleaner.exe
    5. In the right panel, double click on the Default string value and in the Value and in the box which opens, enter the path of the executable i.e. C:\Program Files\CCleaner\CCleaner.exe
    6. Now in the right side empty space again Right click | Select New | String Value. Name the key as Path. Double click and give it the value as the folder path i.e. C:\Program Files\CCleaner\
    7. Now you can close the Registry Editor and from Start | Run type in Application name i.e. CCleaner it would open the Application.
    Captain
  1. Posts : 186
    Nice.
    You could also add the path the the Environment Variables: Path, if you'd rather not mess with the Registry directly.
  2. Posts : 22,814
    W 7 64-bit Ultimate
    Looks good Cap'n!
  3. Posts : 4,772
    Thank You Ted !!
  4. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Very good, Captain - and useful. Good job.
  5. Posts : 4,772
    Thanks Carl !!
  6. Posts : 1,325
    Windows7 Ultimate 64bit
    Very good, Capt'n... Btw, as Loki said earlier, there is another way to do this. All you need to do is add the "Path" of the corresponding program to "Path" environment variable, it's under "Advanced system settings"->"Environment Variables" button.
    zzz2496
  7. Posts : 1,747
    window's 7
    another tweak.!!. thanks Capt .
  8. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    Nice work, Mr. Sparrow!
  9. Posts : 4,772
    zzz2496
    Yes we can do it that way. Also another easy way is to just Create a shortcut of the application or program. Rename it to any short name and place this shortcut in the Windows folder.
