Outlook - General Troubleshooting Guide for Issues
    General Troubleshooting Guide for Issues with Microsoft Outlook
    General Troubleshooting Guide For Issues with Microsoft Outlook
    [info2]These are some General troubleshooting steps to fix Outlook issues like unable to open or crashing while doing something in Outlook etc. [/info2]
    1. Start up problem of Outlook
    This is one of the most common problems with Microsoft office. Whenever this problem occurs the Office comes up with an error message "Cannot start Microsoft Office Outlook".
    This error can persist even after repairing and reinstalling the software. By this time the program also cannot be started in the Safe Mode. The possible reason behind this issue may be the wrong way of outlook shutdown which in turn leads to a problematic navigation panel. One way of resolving the error is by running the “Outlook.exe /resetnavpane “command.
    Start | Run | Outlook.exe /resetnavpane and Hit Ok that would open your Outlook.
    2. PST file problems
    Often the computer users may come up a PST file problem while using the Office Outlook. A corruption in the PST (Personal Storage Table) leads to a damaged inbox where all your vital information is stored. Several troubleshooting methods are there to solve the problem. First try to run from the Safe Mode to identify the cause of the problem. If it does not work, then there is 100% chance of PST corruption which can be handled by an official tool popularly known as Outlook Inbox Repair Tool.
    3. The Mail Client Error
    Another most serious error in the Outlook is the "Mail Client" Error. The Office Outlook troubleshooting methods can help you in solving this problem.
    GoTo Start | Regedit
    HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail\Microsoft Outlook
    and delete Microsoft Outlook and close the Registry Editor.
    Then GoTo Start |Control Panel | Programs and Features. Select the Office click "Change". At the last step click on "Repair" followed by clicking the "Continue" button.
    4. General Issue Troubleshooting
    Most of the Errors and Issues can be fixed by running a Office Diagnostic.
    5. Damage Add-ins Issue
    And most of the crashes like non-responding or freezes in middle of something most of the time it used be a bad or corrupted add-in. So the best thing to do is Disable add-ins and see if it happens.
    Follow these steps to Disable them
    1. On the Tools menu, click Trust Center, and then click Add-ins.
    2. In the Add-ins box, identify the add-in that you want to enable or disable and note the Add-in type located in the Type column.
    3. Select the Add-in type in the Manage box and then click Go.
    4. Select or clear the check box for the Add-in that you want enable or disable and then click OK.
    In case if you can't open Outlook but you want to disable the add-ins you could use OfficeIns it a great tool to fix such issues.
    For Advance Troubleshooting you could use Outlook Tools. OutlookTools is a support and advanced settings tool for Microsoft Office Outlook. It gives you easy access to Outlook settings and data folders and allows you to change settings that are normally only possible through the registry.
    Captain
  1. Posts : 22,814
    W 7 64-bit Ultimate
    Good job Cap'n!
  2. Posts : 9,537
    Captain,
    When I first got win7 hp 64 bit I had trouble with my setting up account in Outlook
    There is a download called Outlook connector that worked like a charm.
    Don't know if this is of any value to you in this tutorial. If it is great.
  3. Posts : 4,772
    Bare Foot Kid said:
    Good job Cap'n!
    Thank You Ted !!
  4. Posts : 4,772
    The Howling Wolves said:
    Captain,
    Yes i'm aware of that i came across issues with Outlook Connector its installation problem while installing Outlook Connector of Microsoft Office 2010. The error message that appears asks you to install Office Outlook 2003 or 2007 or 2010. Outlook Connector handles email messages, contacts, calendars and also live accounts on different sites. To avoid this problem, install Office 2007 along with Office 2010. Thereafter, try to reinstall Outlook Connector 2010 and configure the live accounts on MSN and Hotmail. Now, resume Outlook 2010 followed by uninstalling Office 2007.
    Captain
  5. Posts : 11,408
    ME/XP/Vista/Win7
    Nice one, Captain.
  6. Posts : 31,250
    Captain,
    Captain
    The outlook connector has been updated recently - I tried it out and it worked without issues on my x64 outlook (x64 win7 Pro)
      My Computers
  7. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Captain,
    Captain
    And it works fine on my 32 bit system.
  8. Posts : 31,250
      My Computers
  9. Posts : 2,736
    Well done Capt. Jack. Another helpful tutorial!
    Cheers!
    Robert
