SF IE Restorator - Troubleshooting General Issues with Internet Explorer
This is small utility for Troubleshooting Internet Explorer issues. It will Flush DNS, Re-register concern dlls for Internet Explorer (3 different types 64-Bit, 32 Bit on 64-Bit OS and 32-Bit) Reset IE to Default settings,...
Dinesh's Complete Internet Troubleshooting Guide
This is your one-stop internet related issues guide. Here I will show you some ways to fix your high speed or dial up internet connection issues with Windows 7.I will show you some very useful and basic steps that you can follow without having...
General Troubleshooting to Fix System Restore Issues
If the System is not able to create System restore point try to Create the restore point manually. If you are unable to create a system restore point manually then you could try these steps
1. Make sure that System Restore is enabled
2....
Windows 7 has some fine in-built diagnostic tools to help you trouble-shoot Windows Media Player issues, which you may be facing.
To open these specific troubleshooting & diagnostic modules do the following:
43727
Type msdt.exe -id WindowsMediaPlayerConfigurationDiagnostic in Start...
