Quick Launch - Enable or Disable
Page 8 of 39 FirstFirst ... 67891018 ... LastLast
  1. Posts : 4
    W7
       #70
    hi! i'we read this tutorial hoping to solve the QL problem and i'm not sure i got it wright. So, did any of you manage to get the QL toolbar to remain after reboot? Or we can't do anything about it?
  2. Posts : 72,058
       #71
    Hello Blinky, and welcome to Seven Forums.
    That was just a isolated issue only for that member. The Quick Launch used in this tutorial works just fine and will remain after a reboot. :)
  3. Posts : 4
    W7
       #72
    i had the same probleme a few minutes ago, the QL would disapear after reboot but just now i downloaded i new theme and it seems it remained on the left side. i don't know if that was the answer to the problem but i don't care, i'm just happy it worked :)
    LE: if you still have such problems you can just use this gadget: http://gallery.live.com/liveItemDeta...264a&bt=1&pl=1
  4. Posts : 72,058
       #73
    Interesting. What theme were you using when it went missing on you?
  5. Posts : 4
    W7
       #74
    it was a custom theme made from the "sun theme"
  6. Posts : 72,058
       #75
    Was this a themepack that you downloaded, or one that you created from within Windows 7 using the normal method?
  7. Posts : 4
    W7
       #76
    let me explain: the custon theme i made it myself from a builtin themepack (i can't remember wich, maybe the default one) with the "sun" colour. in this case the QL toolbar disapeared after reboot. then i downloaded another theme (niers niederrhein), used it and it worked. But i'm pretty sure it was just a coincidence...
  8. Posts : 72,058
       #77
    It may have been. At least we have one possible cause for it when it does happen. Thank you for posting back with this information. :)
  9. Posts : 8,375
       #78
    Another good one! When I came across this one it saw an immediate application to soak up some of the overwhelming items already pinned with the number of those continuing to grow.
    Attached Thumbnails Attached Thumbnails Quick Launch - Enable or Disable-quick-launch-7.jpg
      My Computers
  10. Posts : 25
    Windows 7 Build 7100
       #79
    Brilliant!! I have been wondering about that since I first installed 7085! It's a pity that it's such a chore tho...
