Quick Launch - Enable or Disable
Page 11 of 39 FirstFirst ... 91011121321 ... LastLast
  1. Posts : 2
    Win 7 RC
       #100
    Well i have a problem with quick launch. I started system today and the quick launch was away. So i ve switch it on but my order of icons was gone. So i replace them back and after restart quick launch was away again. I switch it on again and it was same. The system somehow cannt remember that Quick launch is on and the order of icons in it Any ideas how to fix it? Thx
  2. Posts : 72,050
       #101
    Hello Jirik, and welcome to Seven Forums.
    As a test create a new administrator account and see if Quick Launch works better in it. If it does, then you can copy the contents of the old user account's C:\User\(user-name) folders into the corresponding new account's C:\User\(user-name) folders. After everything checks out, you can then delete the old user account from within the new one.
    Hope this helps for now,
  3. Posts : 8,375
       #102
    I haven't run into anything like that so far. On one occasion one of the new toolbars created here disappeared where a simple browse back to the folder for that when using the new toolbar option simply saw it restored.
    For arranging or rearranging icons on any quick launch or other named bar that goes easy as well.
    Attached Thumbnails Attached Thumbnails Quick Launch - Enable or Disable-rearrange-icons-quick-launch-bar.jpg   Quick Launch - Enable or Disable-rearrange-icons-quick-launch-bar2.jpg
      My Computers
  4. Posts : 2
    Win 7 RC
       #103
    Hi Brink. I solved it. Because of Ubisoft and their Anno 1404 (RTS with broken loading games) i ve tried to rename my account as they told me. When i renamed it back on the old name quick launch works again. Idk why the quick launch problem started 4 days after i changed the name of my windows account but there is a lot of mysteries around Windows
    P.S. sry for my "English"
  5. Posts : 72,050
       #104
    Jirik,
    I'm happy to hear that you got it sorted. Thank you for posting back with your results and solution. :)
  6. Posts : 8,375
       #105
    Glad to hear the news on that one! xJirikx Typical isn't it? Always one little thing!
    I find the Quick Launch or any additional toolbar essential when running Windows on the Virtual PC now seen for 7 there since you often lack viewing area with the smaller desktop with everything getting cramped up a bit when you have a lot on there too!
    Attached Thumbnails Attached Thumbnails Quick Launch - Enable or Disable-quick-launch-bar-vpc.jpg
      My Computers
  7. Posts : 48
    Windows 7 Professional 64-bit
       #106
    I've had a question threading through my mind for many a reboot. How did you learn these procedures? I would love to know so that I could learn on my own instead of depending on others. Others helping is a good thing, but I've always wondered. I've poked around under the hood myself over the years, but the good stuff always comes from someone else's talent.
  8. Posts : 8,375
       #107
    Hello Barefoot and welcome to the Se7enforums!
    If you browse through the large volume of tutorials here and on the VistaForums Vista Forums pay close attention to who wrote the majority of them to find out who devoted a great deal of time and energy into them! It won't be too hard to figure that one out!
      My Computers
  9. Posts : 72,050
       #108
    Hello Barefoot, and welcome to Seven Forums.
    I found that the best way was through very good backups and a lot of trial and error, digging, and reading. Pick one item and work with it until you are familiar with it, then move on to the next item and so on and so on.
    Don't worry, you'll get there in time and practice. When you have any questions, please post them in the forum. We'll be happy to help as we can. :)
  10. Posts : 8,375
       #109
    I have a better screen here to illustrate how handy having more then toolbar available can be. The other screen posted there only shows one for the host and Virtual PC while this will show how multiple bars are a must when having a system loaded up with all kinds of programs as well as some basic step saving options.
    Rather then posting two desktops you'll note the insert to have a better idea since one would cover the other over.
    Attached Thumbnails Attached Thumbnails Quick Launch - Enable or Disable-new-ttoolbars-multiple.png
      My Computers
