Quick Launch - Enable or Disable
Page 13 of 39 FirstFirst ... 3111213141523 ... LastLast
  1. Posts : 797
    Windows 7 Ultimate (x64)
       #120
    Thanks for the tutorial! It helps a lot and I do need the QL (and no, I don't think that pinning to the taskbar achieves the same purpose)!
    However, here's my experience on the QL disappearance - it stays where it is as long as nothing major happens to the system, i.e. nothing gets installed. If I install a new theme - say by downloading from the MS Windows 7 site - sometimes the QL disappears on the next reboot. It has also disappeared after I have installed Samurize - although it now runs fine along with my Samurize config. Why would it disappear after a theme or a program would get installed - I do not know.
  2. Posts : 72,052
       #121
    You're welcome Unifex. Thank you for the addition information that may help those that may have QL disappear on them for no reason.
  3. Posts : 1
    win 7 ultra
       #122
    Thanks for that - I really mised the quick launch bar and was bugged how the way programs pinned to task bar worked :)
  4. Posts : 72,052
       #123
    You're welcome Sabbietage, and welcome to Seven Forums. :)
  5. Posts : 341
    W7 Ult x64, W8 Pro x64 and W10 Pro x64
       #124
    I could create the Quick Launch. It was placed in the System Tray area as the tutorial indicates. My problem is how to move it adjacent to the Start button as is the case with Vista. I think I am following the step 8, B) but the Quick Launch does not move.
    I wonder what I am doing wrong. Could anyone help?
    Edit: I could manage to do it.
  6. Posts : 19
       #125
    Thanks so much for this. I really missed my traditional quick launch....
  7. Posts : 72,052
       #126
    You're welcome Spagnum, and welcome to Seven Forums. :)
  8. Posts : 341
       #127
    Thanks to this tutorial I could turn on the Quick Launch. However, for some reason it was undone by the process of rebooting the system. I brought back the Quick Launch following the same procedure again but to no avail. What could be wrong?
  9. Posts : 72,052
       #128
    Hello Churin,
    As a test, create another administrator account to see if it works ok in it.
  10. Posts : 341
       #129
    Hellow Brink,
    I did what you suggested and found no such problem on the new account. I turned on Quick Launch once again on the original account but the same problem repeated.
    There must be something wrong with the personal profile for the original account. One solution is to rebuild a new personal profile from scratch. But is there any further suggestion to possibly pin point what the cause of this problem is? If so I would rather pursue that rout even though it takes more time than rebuilding the profile.
