Administrative Tools - Add or Remove from Start Menu
Page 2 of 2 FirstFirst 12
  1. Posts : 72,062
    georgescarlett said:
    Brink said:
    Ah, ok. They are missing in the Administrative Tools folder. The tutorial below will help show you how to restore the missing ones for your edition of Windows 7. :)
    Administrative Tools - Restore Shortcuts
    Maybe I spoke too soon - when I right click on the Desktop then click Adminstrative Tools, they are listed but when I click on any of them I get a message saying: 'Windows cannot find C:\ProgramData\Windows\Start Menu\Programs\Adminstrative Tools\Computer Management.lnk’
    Strange. As a test, download and merged the EXE and LNK (lnk) options in the tutorial below.
    Next, do this tutorial below to restore all of the items in Administrative Tools.
  2. Posts : 6
    64
    Phew – I’ve done it – I can’t believe I was able to follow those instructions - my earlier cri de couer wasn’t an exaggeration - but all’s well – thanks!
  3. Posts : 72,062
       #12
    That's great news Greorge. I'm happy to hear that all is well now. :)
  4. DPG
    I have a follow up question on this topic.
    We have restricted the users so that they cannot change the settings for taskbar and start menu trough an GPO.
    Now we do want to give them the option to change the taskbar settings, this also comes with the option to change the start menu. No worries so far, through the same GPO I took away most of the menu items we don’t want to show. But the administrative tools option is the only one we can’t remove from that setting list.
    So I have written 2 ADM files based upon the reg settings that you give here(see below).
    They hide the administrative menu just fine, but and this is my biggest problem, they still can make it visible again through the start menu options.
    Now here is the pickle, is there a way to completely hide it from the users without changing the image we use?
    Start of ADM file1:
    CLASS USER
    CATEGORY "Start Menu Administrative Tools(CustomADM)"
    POLICY "Remove Administrative Tools from Start Menu"
    EXPLAIN !!ADMHelp
    KEYNAME Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
    PART !!ADM_Configure DROPDOWNLIST REQUIRED
    VALUENAME "Start_AdminToolsRoot"
    ITEMLIST
    NAME !!ADMoff VALUE NUMERIC 0 DEFAULT
    NAME !!ADMon VALUE NUMERIC 1
    END ITEMLIST
    END PART
    END POLICY
    END CATEGORY
    [strings]
    ADM_Configure="Set the Administrative Tools to:"
    ADMoff="Hidden"
    ADMon="Visible"
    ; explains
    ADMhelp="Set Administrative Tools to be shown or hidden on the Start Menu."
    Start of ADM file2:
    CLASS USER
    CATEGORY "All Programs Administrative Tools(CustomADM)"
    POLICY "Remove Administrative Tools from All Programs"
    EXPLAIN !!ADMHelp
    VALUENAME "StartMenuAdminTools"
    ITEMLIST
    END ITEMLIST
    END PART
    END POLICY
    END CATEGORY
    [strings]
    ADMoff="Hidden"
    ADMon="Visible"
    ; explains
    ADMhelp="Set Administrative Tools to be shown or hidden in All Programs."
  5. Posts : 72,062
       #14
    Hello DPG, and welcome to Seven Forums.
    Administrative Tools that you see in the Start Menu is just a hidden system folder located at the path below with shortcuts in it. You could add a line to delete this folder to have it no longer be available in the Start Menu.
    C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    Do note that the shortcuts in this folder point to system files in the "C:\Windows\System32" folder that could be used instead if they really wanted to run them. Luckily, most require you to be an administrator to open and/or use.
    Hope this helps, :)
  6. DPG
    Thx although this is a working solution, and i also have played with rights and SetACL, wich also works. I am still looking for a solution through a GPO.
    Thx for helping :)
  7. Posts : 72,062
       #16
    You're welcome.
