Install Windows 7 from USB Pen Drive Using Grub4Dos
    Install Windows 7 from USB Pen Drive/External Hard Disk Using Grub4Dos
    How to Install Windows 7 from USB Pen Drive/External Hard Disk Using Grub4Dos
    **(Update: 19th January 2011)**
    The below tutorial was written base on MultiBootISO.exe version 1.4.8 which is not the lastest version. If you like this version(V1.4.8), you may get it here: MultiBootISOs-v1.4.8.exe
    Latest version of MultiBootISO.exe is different than the version descripted in this tutorial.
    **End of update: 19th January 2011)**
    **(Update: 5th August 2010)**
    Here, in this quote, are some of the updated informations to this tutorial.
    Recently, in the early of July 2010, Windows 7 Installation boot entry has been added into MultiBootISO.exe. We don't have to do it manually as described below.
    All you need to do is:
    Step 1: Download MultiBootISO, run and install it into your USB Pendrive/External Hard Disk
    Step 2: As for fresh install, you only need to copy the following 3 file/directorys into the root directory of your USB(thanks for climbing for this info):
    bootmgr (file)
    boot (directory)
    sources (directory)
    Thats it. Reboot your computer from USB. From the boot menu, choose Operating System Installers > Install Windows Vista/7
    This Installation process of Windows 7/Vista will start. Good Luck.
    **End of Update 5th August 2010**
    Requirements:
    1. MultibootISO > Install Grub4Dos easily into USB Flash Drive/External Hard Disk
    Get it here: Boot Multiple ISO from USB (MultiBoot USB) | USB Pen Drive Linux
    or here: YUMI - Multiboot USB Creator (Windows) | USB Pen Drive Linux
    2. Windows 7 DVD, ISO or Source Files
    3. Notepad++ > To edit menu.lst
    Get it here:Notepad++ | Download Notepad++ software for free at SourceForge.net
    or here: Download Notepad++ 5.6.8 - FileHippo.com
    Lets Start
    Step 1: Run MultibootISO, install MultibootISO into your USB Storage Device(ie.pendrive, External Hard Disk). This will install Grub4dos in pendrive.
    Step 2: Copy everything in Windows 7 Installation DVD into your USB storage.
    Step 3: Look for the file menu.lst in your pendrive/External Hard Disk, edit it with Notepad++.
    Step 4: You'll be able to see the first 9 rows as below in menu.lst
    # This Menu Created by Lance http://www.pendrivelinux.com
    # Ongoing Suggested Menu Entries and the Suggestor are noted!
    default 0
    timeout 30
    root=(hd0,0)
    color NORMAL HIGHLIGHT HELPTEXT HEADING
    splashimage=(hd0,0)/splash.xpm.gz
    foreground=FFFFFF
    background=0066FF
    Add in the below command lines after the above code:
    title Install Windows 7
    root (hd0,0)
    chainloader (hd0,0)/bootmgr
    Done. The pendrive is ready to boot and install Windows 7.
    If you are confused and don't know how to edit menu.lst, then, open it with Notepad++, delete all the command lines and replace by the following command lines. Save the file and exit.
    default 0
    timeout 30
    root=(hd0,0)
    foreground=FFFFFF
    background=0066FF
    root (hd0,0)
    The steps mentioned in this tutorial work with Windows Vista too.
    Install from Pendrive
    Restart the computer. Configure BIOS to boot from Pendrive/External Hard Disk.
    A boot menu will appear. You will be able to see the boot option Install Windows 7.
    Use arrow key on keyboard to select Install Windows 7 and press enter.
    This will enter Windows Boot Manager, choose Windows Setup [EMS Enable] and the installation will start.
    If you install MultiBootISO(Grub4Dos) in 2nd or 3rd partition of your external hard disk, you need to change all the (hd0,0) in menu.lst to (hd0,1) or (hd0,2).
    (hd0,0) means 1st hard disk, 1st partition
    (hd0,1) means 1st hard disk, 2nd partition
    (hd0,2) means 1st hard disk, 3rd partition
    Grub4Dos will treat your Pendrive/USB Hard Disk as 1st hard disk, but you have to define the path to 2nd or 3rd partition.
    For example:
    Install MultiBootISO(Grub4Dos) in 2nd partition=
    root (hd0,1)
    chainloader (hd0,1)/bootmgr
    Install MultiBootISO(Grub4Dos) in 3rd partition
    root (hd0,2)
    chainloader (hd0,2)/bootmgr
    About Menu.lst
    Menu.lst is a boot menu of Grub4Dos. After install MultibootISO into pendrive/External Hard Disk, it support for booting many OS or programs. There are many entries ready made by default after installing MultibootISO. You may delete any of the entries if you don't need them.
    For more info about MultiBootISO, please visit: Boot Multiple ISO from USB (MultiBoot USB) | USB Pen Drive Linux
    Advantages of Using Pendrive to Install Windows 7
    DVD will take 30 minutes to install Windows 7
    but, Pendrive will take 15 minutes to install Windows 7. (for USB 2.0 & above)
    Advantages of using Grub4Dos
    There are many several ways to install Windows 7 from USB Pendrive.
    Microsoft has officially released a software which can transfer Windows 7 DVD into pendrive.
    WintoFlash is another software will do the same thing.
    However, these 2 software will only allow 1 OS at a time.
    But, by using Grub4Dos, many other bootable OS or Softwares (ie, Linux, Ubuntu, Ultimate Boot CD, Partition Wizard...) are supported in one single pendrive/External Hard Disk. To view the list of supported software, you may refer the official site of MultiBootISO. If the bootable software you owned is not listed, doesn't mean it is not supported.
    Besides installing Windows 7, you can make your USB become a Super System Maintenace & Emergency Rescue Tools. (i.e, recover/copy files when Windows cannot startup/lost partition/formated partition, reset or recover system/windows password, testing tools)
    Below are some of the highly recommended bootable software for System Maintenance & Emergency Rescue Tools:
    1. Partition Wizard - Site - Download
    2. Hiren's Boot CD - Site1 - Site2 - Download
    3. Ultimate Boot CD - Site - Download
    4. Windows 7 System Repair Disc - How to boot Windows 7 Repair Disc from USB using Grub4Dos
    5. AntiVirus Rescue Disk (ie, AVG, Bitdefender, Avira)
  1. Posts : 15
    XP/7
    im having trouble with your download links. Can you double check them please?
    *EQL*
  2. mjb
    Windows 7 & XP
    Em... the links is working.
    However, I have made some adjustment of the link.
    Try that if you could download it or not.
    Which download, you can't access?
  3. mjb
    Windows 7 & XP
    tutorial minor update
  4. Posts : 22,814
    W 7 64-bit Ultimate
    Hello mjb, this looks very useful; thanks!
  5. Posts : 12,177
    Thanks for the tutorial, this works very well and actually is easy to do.
    You can make very easy to use and fast installation for help tools on your USB memory stick.
  6. mjb
    Windows 7 & XP
    minor tutorial update.
    > Link added for download MultiBootISO.exe version 1.4.8
  7. Posts : 28
    windows 7 ultimate 64bit, Win 7 Ul x86, XP
    why not update this tutorial? if you have time.do we actually got to put the 3 files in the directory now since they have windows 7 listed
