SF Diagnostic Tool - Using for Troubleshooting
Page 15 of 23 FirstFirst ... 51314151617 ... LastLast
  1. Posts : 12
    Windows 7 Professional x64
       #140
    Possible bug?
    This program works and all, but I had a slight issue.
    When I run it, it generates the folder on my desktop. Afterwards, the folder is empty.
    I ran it again to see if it would copy the files this time, and when it asked me about replacing files I found that it creates a Desktop folder on my main hard drive (C:/Desktop/SF_)
    Just wondering if this was a bug, or just something that happened to me? Anyway, it worked. Thanks!
  2. Posts : 72,051
       #141
    Hello Stickman, and welcome to Seven Forums.
    Did you by chance move your user profile folder to another drive from the default C: Windows drive location?
    If so, then that would be why since the program only saves the folder to the C:\Users\(user-name)\Desktop location. There was some issue with it not being able to use the %UserProfile%\Desktop variable to have the folder saved to wherever you have your profile at.
  3. Posts : 6,285
    Windows 10 Pro X64
       #142
    I just noticed a typo on the first post in this tutorial
    4. Click/tap on the Grap All button, and click/tap on OK for each notice dialog until it's finished.
    Grab is misspelled.
  4. Posts : 72,051
       #143
    LOL, good thing it wasn't a C instead of G. :)
  5. Posts : 12
       #144
    Hey, sorry for not replying earlier but haven't been feeling brilliant lately.
    Anyway, my user folder is in the default location, and the tool finds it because it still creates the folder on my desktop, but puts the files the other folder.
    So I'm not sure, but if it only affects me I'm sure it doesn't matter because I have the results anyway.
  6. ace
    win 7 XP
       #145
    Thanks for the help, but I have a couple of questions.
    1. I ran the tool and it did save it to my destop, but I'm not sure how it did it. How do I set my user profile to:
    C:\users\username\desktop?
    2. I've included a screen shot of the files that SF tool saved to my desktop. The dmp. file is at the top. Is that the file that I would load into bluescreenview or whocrashed?
    Attached Thumbnails Attached Thumbnails SF Diagnostic Tool - Using for Troubleshooting-sf-diag-tool-files.png
  7. Posts : 72,051
       #146
    Hello Ace,
    That would be correct. You would want to load the .dmp file. :)
    If you like, the information at the link below is nice source to help with debugging.
    Crash and lockup debug 'How To' - Windows 7 Help Forums
  8. Posts : 58
    windows 7 premium x64
       #147
    SF Diagnostic Tool Stuck, cant get logs.
    so i was going to make a thread to try to solve my bsod but i have been stopped by this.
    spoiler/ See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.IOException: Could not complete operation on some files and directories. See the Data property of the exception for more details.
    at Microsoft.VisualBasic.FileIO.FileSystem.FxCopyOrMoveDirectory(CopyOrMove operation, String sourceDirectoryPath, String targetDirectoryPath, Boolean overwrite)
    at Microsoft.VisualBasic.FileIO.FileSystem.CopyOrMoveDirectory(CopyOrMove operation, String sourceDirectoryName, String destinationDirectoryName, Boolean overwrite, UIOptionInternal showUI, UICancelOption onUserCancel)
    at Microsoft.VisualBasic.MyServices.FileSystemProxy.CopyDirectory(String sourceDirectoryName, String destinationDirectoryName, Boolean overwrite)
    at SF_Diagnostic_Tool.Form1.Button1_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    /spoiler
    idk how to do spoilers sry
    also tried to look in event viewer and got this.
    Attached Thumbnails Attached Thumbnails SF Diagnostic Tool - Using for Troubleshooting-2013-04-02-07_39_50-sf-diagnostic-tool.png   SF Diagnostic Tool - Using for Troubleshooting-fbjazbw.png
  9. Posts : 4,772
       #148
    /spoiler
    Seems like that's why it's not working. Instead of Grab All try to do it one by one.
  10. ace
    win 7 XP
       #149
    Brink said:
    Hello Ace,
    Thanks for the info. This will help me get started.
