Partition Wizard : Use the Bootable CD
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 579
    Windows 7 64-bit Home
    thank you very much for all the help and tutorials, i appreciate it
    is there a section on what partitions can be used for and a general way to set them up? sorta the pro's and con's of having more or less partitions. this tutorial mentions needing extra software to enable 4 partitions, i dont know why i would ever need more than one... id really like to learn tho!
  2. Posts : 22,814
    W 7 64-bit Ultimate
    Hello again, thank you; it's my pleasure to help people.
    There are many reasons for more than one partition, one being the desire to keep all your personal data, i.e. music, docs and pics, separate from the Windows Operating System (OS) so that if the need ever arises to reinstall the OS all the data stored on another, separate partition will not be lost. Another is the ability to dual or multi boot.
  3. Posts : 4
    Windows 7 Professional x64
       #12
    Hi BFK,
    just wanted to say thanks for the tutorial, really helped
  4. Posts : 22,814
    W 7 64-bit Ultimate
    Hello Unibond7, welcome to Seven Forums!
    I'm pleased it was a help to you and thanks for the feedback.
  5. Posts : 9
    Win 7 Professional x64
       #14
    Hi BFK, just want to thank you for the tutorial, made my job very easy. I used Option 1 and wound up with 3 primary and 1 logical partition. I do plan to try to change the logical to primary just didn't want to the first try for fear it would mess things up. I now have a 100 GB Windows 7 partition and 365 GB for documents and other data. Now I just need to find the tutorial for moving documents and I'll be all set. Thanks again.
    Repped with pleasure
  6. Posts : 22,814
    W 7 64-bit Ultimate
       #15
    HelloCaveat.
    This should be a help; you're welcome and thanks for the feedback.
    User Folders - Change Default Location
  7. Posts : 9
       #16
    Hi BFK, thanks for the link. Tutorial worked like a charm.
  8. Posts : 22,814
    W 7 64-bit Ultimate
       #17
    You're welcome!
  9. Posts : 3,427
    Hi Ted, as you are the resident PW wizard can you tell me, is doing a secure delete "write 0's" (or whatever it's called... the quicker one) with PW sufficient to stop data being recovered from the drive? I aquired a new HDD recently, and the previous owner was very keen that I zero it.
  10. Posts : 22,814
    W 7 64-bit Ultimate
       #19
    Hello Martin.
    If the HDD is connected to the PC and Windows is running, you can open an elevated command window and do the clean all #7 of this tutorial at the link below, it'll do just as good as PW, if not better as it's Windows on Windows.
    It'll write one set of zeroes to the entire HDD.
