Partition Wizard : Use the Bootable CD
Page 4 of 4 FirstFirst ... 234
  1. Posts : 10
    Windows 7 Ultimate 64bit
       #30
    sorry if i post this here cuz i couldn't find the related topic,is there any way to copy win 7 os from an installed partition to another one in the same hard disk without loosing data?
  2. mjf
    Windows 7x64 Home Premium SP1
       #31
    This is more of an imaging problem. The short answer is yes you can but it involves a few steps and comes with some risk because things can go wrong.
    Maybe post a screen shot of your HDD partitions using Windows Disk management and the snipping tool. Can you give the reason why you basically want to do this move.
  3. Posts : 10
       #32
    Thanks mjf for ur reply,its just a question that i wanna to know about it,so is it possible?
  4. mjf
       #33
    As I said yes it is possible.
  5. mjf
       #34
    SCANNERMAN777 said:
    *As a side note, don't bother with that RE-IMAGE program being offered here. Trust me, it's garbage.
  6. Posts : 241
    Windows 7 Ultimate, Windows 8.1 Pro, Linux Mint/Cinnimon (Triple Boot)
       #35
    It's not the same program as Partition Wizard. I apologise if I didn't make that clear.
