Partition Wizard : Use the Bootable CD
Use the Bootable Partition Wizard CD to Make Changes to the Windows Partition Structure
This outlines several uses for the Partition Wizard Bootable Disk (PWBD) some of which Windows is not able to do natively, to include converting an Extended partition / Logical drive to a Primary partition, to wipe secure erase a single partition and how to Shrink/Resize the left side of a Windows partition.
Partition Wizard is a very reliable tool for your tool kit and it's a free download for home / personal use, first download the PWBD ISO file to the desktop, be sure to get the PWBD and not the installed version; scroll down to see the download link for the Bootable CD ISO file at this link below.
Partition Wizard Free Bootable CD
Then you will need to burn the ISO to a CD, it was designed for use and works best from a CD rather than a DVD; it doesn't take any input at all from the user for Partition Wizard CD to setup, just relax and let it load all on its own.
   Warning
As with anything that makes changes to the Windows structure there is always the chance for an error to occur, it would be advisable to make reliable backups to the external media of your choice of any important data, i.e. pictures, music or documents, that you would not want to lose before you make any changes to your system.
Let's get started!
To boot the disk, in the BIOS set the PC boot order to boot first from the CD/DVD drive, insert the PWBD and restart the PC, it'll take a few minutes for it to setup with no input from the user needed.
Once the program has started you can remove the CD from the drive if you like.
Option One
Convert Extended / Logical to Primary
There are many reasons one may want to convert an Extended partition / Logical drive to a Primary partition, though I'm just going to show how here without going into why; this first snip below shows the partition structure I'm starting with.
Have a look at Method Two in this tutorial for a totally different type option.
Partition / Extended : Logical Drives
click an image to enlarge
1) In the PW program right click the Extended / Logical to be converted and click Modify then click Set as Primary.
2) At the top left in the action bar click Apply then click Yes for the "Apply Changes" conformation dialog box; the whole process only takes seconds.
3) Then OK for the "Successful" dialog box and this is what you will have.
That's all, you're finished; remove the CD from the drive, at the upper left corner click General then Exit to close the Partition Wizard program and restart Windows.
Option Two
Wipe a Partition
   Warning
This method will completely overwrite any Partition or entire Hard Disk Drive / Solid State Drive that it's pointed at, it's known as a secure erase and after it finishes any and all data will not be recoverable at all, even by the best data recovery software so copy out or backup anything you don't want to lose before you start this procedure.
To be sure you have the correct partition for the wipe, type diskmgmt.msc into the Windows start menu start search box to view Windows disk management.
1) In Partition Wizard right click the partition you want to wipe secure erase and click Wipe Partition.
2) Select the type wipe you want in the dialog box that opens and click OK.
3) At the top left in the action bar click Apply; then for the "Apply Changes" dialog box click Yes to start the wipe.
4) You will get a Pending box during the wipe; to do this 30GB took less than 20 minutes, on average they take about 1 hour per 300GB to complete; when it finishes click OK for the "Successful" dialog box.
Option Three
Shrink the Left Side of a Windows Partition
The issue here is that Windows disk management will only shrink a partition from the right side, it will not natively shrink the left side of a partition and Partition Wizard will; this is useful in this type situation where you need to add space to the Windows C: partition and there is an existing data partition in the way and nowhere to move the data.
1) In the Partition Wizard program right click the partition you want to shrink and at the very top of the drop down menu that opens click Move/Resize.
2) In the Move/Resize box click to hold and drag the left side of the border / slider and drag it to the size you want to shrink the partition and click OK.
3) At the top left in the action bar click Apply then click Yes for the "Apply Changes" conformation dialog box.
4) You will get a "Pending" graph but it depends how much data that has to be moved to know how long it will take, just relax and let it work without interruption; when it finishes click OK for the "Successful" dialog box.
This will give you unallocated space in Windows disk management that can be created into a completely new partition or the Windows C: partition can be extended into the created unallocated space so the C: partition can be expanded; see the second snip down.
Enjoy! :)
Nice tutorial BFK, this will help a lot, always seems to be questions on how to do this.
76~2.0
Intel Core i5-3570K 4.6GHz
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
Hello Dave, that's why I did it, I hope a lot of people find it useful.
* BFK Customs *
W 7 64-bit Ultimate
Intel Q9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
ATI : XFX 5870
Realtek HD Audio 7-1
1920x1080P & 1920x1200
Corsair 620HX
Cooler Master RC-690
Microsoft 500
Razer Diamondback 3G
14 Mb/s
It looks perfect to me.
I'll keep it at the top of my Bookmarks and refer Users to Options 1-3 to see how they get on.
(You should be repped for your hard work by everyone who uses this, by clicking the scales in your posts above and saying thanks! )
Thank you very much Greg.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Note you can also wipe the entire HD from the Disk tab. It offers various levels of zeroing (one is enough) up to 3 passes which is the DOD standard.
Thanks Greg, I'll have a look at that.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Thanks a lot BFK, for this very helpful and informative post.
HP HDX16T
Windows 7 Home Premium 64 Bit
Intel Core 2 Duo CPU P8700 @ 2.53GHz
4.00GB
NVIDIA GeForce GT 130M
16" 1080P
Hello Chris H, welcome to Seven Forums!
I'm very glad it was a help to you, thanks for the feedback.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Barefoot, I believe that running Startup Repair to repair the MBR is a critical enough step that it should have an illustrated Step 4 in Option One, rather than just a note that might be missed.
thank you very much for all the help and tutorials, i appreciate it
is there a section on what partitions can be used for and a general way to set them up? sorta the pro's and con's of having more or less partitions. this tutorial mentions needing extra software to enable 4 partitions, i dont know why i would ever need more than one... id really like to learn tho!
My First Build
Windows 7 64-bit Home
Intel Core i7-870 Lynnfield 2.93 Ghz
Asus P7P55D-E Pro
8GB 4x2 A-Data 1333 Mhz
HIS Radeon HD 5850 1GB
Onboard
Dell S2440L 24"
1080p
120 GB Intel X25-M SATA Solid State Drive ///
1 TB Western Digital Caviar Black SATA 6gb/s 7200rpm Drive
Corsair 650TX 650 Watt
Antec Three Hundred
Stock Intel /// 4 Antec Case Fans /// NZXT Sentry-2
Logitech LX 710
Logitech LX 710
LG Blu-Ray Drive
Hello again, thank you; it's my pleasure to help people.
There are many reasons for more than one partition, one being the desire to keep all your personal data, i.e. music, docs and pics, separate from the Windows Operating System (OS) so that if the need ever arises to reinstall the OS all the data stored on another, separate partition will not be lost. Another is the ability to dual or multi boot.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hello Unibond7, welcome to Seven Forums!
I'm pleased it was a help to you and thanks for the feedback.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hi BFK, just want to thank you for the tutorial, made my job very easy. I used Option 1 and wound up with 3 primary and 1 logical partition. I do plan to try to change the logical to primary just didn't want to the first try for fear it would mess things up. I now have a 100 GB Windows 7 partition and 365 GB for documents and other data. Now I just need to find the tutorial for moving documents and I'll be all set. Thanks again.
Repped with pleasure
HP Pavilion dv6 - 3155dx Entertainment Notebook
Win 7 Professional x64
Intel i3
Hewlett-Packard 144C 65.35
3894 Megabytes Usable Installed Memory
Intel(R) HD Graphics [Display adapter]
IDT High Definition Audio CODEC Intel(R) Display Audio
Generic PnP Monitor (15.3"vis)
1366 x 768
TOSHIBA MK5056GSY [Hard drive] (500.11 GB)
SMART Status: Healthy
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hi BFK, thanks for the link. Tutorial worked like a charm.
Intel i3
1366 x 768
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hi Ted, as you are the resident PW wizard can you tell me, is doing a secure delete "write 0's" (or whatever it's called... the quicker one) with PW sufficient to stop data being recovered from the drive? I aquired a new HDD recently, and the previous owner was very keen that I zero it.
Intel Core i5 7400 @ 3.00GHz
OEM supllied with PC
Realtek
Acer Al1980 + HKC
1TB Toshiba
1TB WD Caviar Green
120GB Samsung Evo 840
OEM Supplied
Logitech Wireless
Logitect Wireless
40Mb/s Down 10Mb/s Up
Defender
Hello Martin.
If the HDD is connected to the PC and Windows is running, you can open an elevated command window and do the clean all #7 of this tutorial at the link below, it'll do just as good as PW, if not better as it's Windows on Windows.
It'll write one set of zeroes to the entire HDD. ;)
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
