MTU Limit - Test and change your connection's MTU limit
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 1,113
    windows 7 professional & ultimate 64bit laptops
    thank you!
  2. Posts : 1,663
    Windows 10 Tech Preview 9926 x64
    Thank you so much for this...finally I can connect to Xbox Live through my tethered EVO. +Rep
  3. Posts : 3,322
    Windows 8.1 Pro x64
       #12
    Happy to hear it helped :)
  4. Posts : 3
    Windows 7 professional
    Help me plz
    Ok so i know that your optimal mtu size is not suppose to be under 1400 but mine is 900 what is going on here can anyone help me
  5. Posts : 3,322
    Windows 8.1 Pro x64
       #14
    Is that what you've set, or is that the default of it in Windows?
  6. Posts : 1
    Windows Vista Ultimate 64bit
       #15
    I have a D-Link DLG-4500 that allows the setting of the MTU and is set by default to 1500 (at max). My Windows interface connection was set to 1504. I used your tutorial to determine the appropriate MTU and it turned out to be 1476, with the extra 28 bytes that equals 1504. Should I decrease the value of the Windows interface to be equal to that of the router, and if not what problems could that cause?
  7. Posts : 3
       #16
    thats what i get when i do the mtu packet to like google and such i was trying to find my optimal through cmd prompt and i can't get above 900 or it says i have to defragment it more.
  8. Posts : 3,322
    Windows 8.1 Pro x64
       #17
    If it's too high then all you'll get is packet loss with your connection. Setting the correct MTU limit just offers a smoother connection. In a nutshell. You can decrease it to 1500 yea, it won't cause any problems.
    What's your current setup for your connection i.e. do you use wireless, or wired connection etc?
  9. Posts : 3
       #18
    I have a wired connection i wont use a wireless. I think it is just my ISP they are complete crap. I pay 70 dollars a month for 1.5Mb and i usually get 400-500Kb which is ridiculous, its the only thing i can get here. But, other then that idk what it could be at all.
  10. Posts : 65
    windows7 sp1 home premium 64bit
       #19
    mine was 1460 at its best i still kept getting 25% loss it was going back and forth with 0% loss and sometimes 50% loss and when i would switch to 1461 it was worst same with 1459 i ran each like 10 times before deciding which one was the best .
    But i couldn't find one tha was 0% loss all the time ,is this normal?
