MTU Limit - Test and change your connection's MTU limit
Page 4 of 4 FirstFirst ... 234
  1. Posts : 2
    Windows 7 32 bit
       #30
    Hi
    Looking at my router, the MTU is set at 1500 but when I ran the command netsh interface ipv4 show subinterfaces, the results suggests that over the wireless connection, the MTU was 1300 (see attached screenshot). I then ran the ping google.com command and only received successful results at 1272 i.e. ping google.com -f -1 -1272.
    Any suggestions? I've no real expertise in this area but came across the posts as I've been trying to understand why transfers to and from my ReadyNas have been so slow.
    Attached Thumbnails Attached Thumbnails MTU Limit - Test and change your connection's MTU limit-mtu.jpg
  2. Posts : 3,322
    Windows 8.1 Pro x64
       #31
    What wireless device are you using? I think some are limited to 1300.
  3. Posts : 2
    Windows 7 32 bit
       #32
    Thanks for getting back to me.
    I have a Sky router (SR101) running to three Netgear WNDAP360 wireless access units (am connected using 2.4ghz band). I've had a look in the admin pages of the netgear wireless points and can't see any reference to setting MTU. If I can't change anything on these wireless points, is it worth setting the network to run at 1272 (i.e. 28 below the 1300 limit) or is this going to cause things to slow down even further?
  4. Posts : 1
    Windows 7 Home Premium 32bit
       #33
    Flipkart Not open
    I am MTNL Broadband User. I have 1mbps plan and I am using WIFI. My problem is Flipkart.com is not opening in my laptop and my phone also. I tried all your steps but those steps are confusing me and I did not get resolution.
    I ping with "ping google.com -f -l 1472"
    the reply got request time out. (see the attachment capture1.png )
    then i entered "ping google.com -f -l 1462"
    I got reply (see the attachment capture2.png )
    then I add 28 "ping google.com -f -l 1490"
    I got reply:Packet needs to be fragmented but DF set. (see the attachment capture3.png )
    If you have any solution, please help me.
    Thank you.
    Attached Thumbnails Attached Thumbnails MTU Limit - Test and change your connection's MTU limit-capture1.png   MTU Limit - Test and change your connection's MTU limit-capture2.png   MTU Limit - Test and change your connection's MTU limit-capture3.png
  5. Posts : 210
    98SE/XP/windows7 ultimate 32bit
       #34
    1500 work fine for me
  6. Posts : 1
    windows 10 pro
       #35
    i tried it and cmd says:The filename, directory name, or volume label syntax is incorrect.
    please help
  7. Posts : 1
    64
       #36
    This article here from microsoft forms step by step will solve your mtu settings issues from ranges of Windows XP all the way to windows 10. Only difference is the beginning steps are a bit different. The MTU settings in the later steps are just about the same. No reason to use cmd or powershell. Some windows versions do not support certain commands in powershell and cmd. Specially windows 10. Most commands i use on the common version dont work period.
    How to change MTU Settings in Windows 10 - Microsoft Community
