Power Plan - Restore Default Settings
Page 1 of 3 123 LastLast
    How to Restore Default Power Plan Settings in Windows 7 and Windows 8
    This will show you how to reset and restore all of the default Power Plans back with their default settings, or how to restore a single Power Plan back to default settings in Windows 7 and Windows 8.
    EXAMPLE: Default Power Plans
    EXAMPLE: Missing Power Plans
    NOTE: This is just an example of the power plans missing.
    OPTION ONE
    To Reset and Restore All Power Plans to Default
    NOTE: This can be handy if you have a missing default power plan and would like to restore it, or would like to reset all default power plans back to their default settings.
    1. Open a command prompt in Windows 7 or Windows 8.
    2. In the command prompt, type powercfg -restoredefaultschemes and press Enter. (See screenshot below)
    3. Close the command prompt.
    OPTION TWO
    To Restore a Single Power Plan back to Default
    NOTE: This will restore a single power plan that you select back to it's default settings.
    1. Open the Control Panel (icons view) in Windows 7 or Windows 8, click/tap on the Power Options icon, and go to step 3 below.
    2. Click/tap on the Change plan settings link to the right of the power plan that you want to restore the default settings for. (See screenshot below)
    3. Do step 4 or 5 below for what you would like to do.
    4. Click/tap on the Restore default settings for this plan link, and go to step 6 below.. (See screenshot below)
    5. Click/tap on the Change advanced power settings link, click/tap on the Restore plan defaults button, and go to step 6 below.. (See screenshot below)
    6. Click/tap on Yes to confirm. (See screenshot below)
    NOTE: If you did step 5 instead of step 4, then click/tap on OK. (See screenshot below step 5A)
    7. Close the Edit Plan Settings window. (See screenshot below step 4)
  1. Posts : 16
    Windows 7 Ultimate 32-bit (6.1, Build 7600)
    Thanks :) this would be a great help.
  2. Posts : 72,049
    You're most welcome Afrozenminute. :)
  3. Posts : 2
    Windows 8 x64
    Hello and thank you, using this I've just fixed a very annoying problem on my PC :
    Re: Lenovo Power Manager in Windows 8 - Page 4 - Lenovo Community
    BIG THANKS
  4. Posts : 72,049
    You're most welcome Aybe, and welcome to Seven Forums. I'm glad it was able to help. :)
  5. Posts : 2
    Windows 8 x64
    Thank you !
  6. Posts : 297
    Power settings really bricked - Just Repair-Installed
    I ALREADY DID "powercfg -restoredefaultschemes" about 10 dozen times in Elevated Command prompt, it just says, "You do not have the permissions required to perform this action."
    And I just repair-installed this stupid OS! What else is there to break next?
  7. Posts : 72,049
    Hey AG,
    Odd, does using Option Two to manually reset your power plan work for you?
  8. Posts : 297
    It didn't work either. In fact the problem started when I tried to create a custom power plan for my tower.
  9. Posts : 72,049
    If you like, doing a system restore using a restore point dated before this should be able to sort it for you.
