Task Scheduler : Create Shut Down PC Automatically Task
Page 1 of 3 123 LastLast
    How to Create a Task that will Shut Down the PC Automatically
    This will show a very easy way to create a task in the Task Scheduler that will shut down the PC whenever you like. This will work for Windows 7 and Windows Vista.
    Let's get started!
    1) In the Windows start menu search box type "Task Scheduler" (without the quotes) right click the entry and select "Run as Administrator" then enter your user credentials for the UAC prompt and click "Yes" to open the Task Scheduler.
    click an image to enlarge
    Task Scheduler : Create Shut Down PC Automatically Task-search.jpg
    Task Scheduler : Create Shut Down PC Automatically Task-uac-task.jpg
    2) In the left pane of Task Scheduler, click on Task Scheduler Library, then in the "Actions" menu in the right pane click on Create Task.
    Task Scheduler : Create Shut Down PC Automatically Task-create.jpg
    3) In the Create Task window under the General tab, set a name and description for the task then dot "Run whether user is logged on or not" then put a check/tick at "Run with highest privileges", be sure to set the "Configure for:" for your flavor of Windows, then continue on to #4 below.
    Task Scheduler : Create Shut Down PC Automatically Task-general.jpg
    4) Now at the Actions tab at the lower left click "New", in the "New Action" dialog box leave "Action" set at "Start a program" at "Program/script:" type shutdown.exe then at "Add arguments" type /s /f (take note of the space between the /s and /f) then click OK.
    Task Scheduler : Create Shut Down PC Automatically Task-action-new.jpg
    Task Scheduler : Create Shut Down PC Automatically Task-new-action.jpg
    5) Now at the Triggers tab at the lower left click "New" in the "New Trigger" dialog box set the parameters that you want for the task, as everyone's needs will be different, I just highlighted a few of the ones that need to be set to give some ideas.
    Task Scheduler : Create Shut Down PC Automatically Task-triggers-new.jpg
    Task Scheduler : Create Shut Down PC Automatically Task-set-trigger2.jpg
    6) After you have the Triggers set click "OK", you will then be prompted to enter your user credentials one last time and then click "OK" to finish creating the task. That's it the task has been created, at "File" click "Exit" to close the Task Scheduler.
    Task Scheduler : Create Shut Down PC Automatically Task-password.jpg
    Task Scheduler : Create Shut Down PC Automatically Task-exit.jpg
    Be sure to have a look at the "Conditions" tab if you need to add any parameters that must be met before the task is able to run.
    Task Scheduler : Create Shut Down PC Automatically Task-condidions.jpg
    Should the PC be in use at the scheduled shutdown time you will get a dialog box stating that you are about to be logged off.
    Task Scheduler : Create Shut Down PC Automatically Task-warning.jpg
    Enjoy! :)
  1. Posts : 17,322
    Win 10 Pro x64
    Nice work Ted, easy to follow too!
  2. Posts : 22,814
    W 7 64-bit Ultimate
    Thanks Derek! :)
  3. Posts : 53,365
    Windows 10 Home x64
    Very nice Ted, you do good work. A Guy
  4. Posts : 22,814
    W 7 64-bit Ultimate
    Thank you! :)
  5. Posts : 12,177
    Great work Ted, well done :)
  6. Posts : 22,814
    W 7 64-bit Ultimate
    Thanks Dave, I'm pleased you find it useful. :)
  7. Posts : 49
    Windows 7 Pro 64bit SP1
    hi Bare Foot Kid:
    Is there a way to make pc auto restart using the same method?
  8. Posts : 72,052
    Hello Sonshi, and welcome to Seven Forums.
    Yes. You could use the same tutorial, but just substitute the arguments in step 4 with /R instead to restart the computer. :)
  9. Posts : 49
    Thank you Blink.
    I did exactly that. And it work. except that I needed to type my login password to start Windows.
    Windows needs user password in order to use run Task Scheduler and password is again needed to login.
    How can I solve this?
