Windows 7: Device Manager - Finding Unknown Devices
03 Jan 2019   #20
Vineet Garg
Windows 7 Ultimate x32 With Sp1 + Vista Ultimate x32 with Sp1 & Sp2 !!
Hi Sir,
Happy New Year!
I don't think you should disable any fans at all. Now a days people try to install extra coolers/fans to their systems. I am surprised why you want to kill those internal/close fans. They are probably specific to certain parts. They live closer to them & do a good work to keep them cool while case fans maintain overall temperature. So, i think they are actually helping the case fans to approach deeply & keep everything cool.
Though It seems surprising that you are having 4-5 internal fans. I would like to ask did you add those fans on your own or they came with the parts ?
If they came with parts, I feel that the close fans will be doing something that even case fans would fail. They will suck & throw the heat out of the parts. That's essential even if you are having powerful case fans. I think they will keep them clean as well. I know only that much.
Thanks & Regards. ...
03 Jan 2019   #21
F22 Simpilot
Quote   Quote: Originally Posted by Vineet Garg View Post
Hi Sir,
Happy New Year!
I haven't that's why I'm asking why those are set to no. And as I stated my fans are currently running.
Unknown device in device manager after Bios default settings are
applied. Sorry that last word didn't get in the subject line. So: http://i.imgur.com/QoSy2wX.png These two values are: USB\VID_0CF3&PID_3000&REV_0200 USB\VID_0CF3&PID_3000
Drivers
Audio USB Devices showing under Other Devices in Device Manager
Hi! I have two USB audio devices that I cannot seem to properly install drivers for. Focusrite Scarlett 2i2 & KORG MicroKONTROL I am in communication with both product tech support teams but so far they have not offered a successful solution. As the same issue is occurring with multiple...
Hardware & Devices
Imaging Devices - Unknown Device
I have attached a view of what's listed in my device manager because there are two "unknown devices" listed under "Imaging Devices" and I have no idea what they are. The manufacturer is Creative Technology Ltd. but that's about all I know. Every time I start up my PC I get the message, "updating...
Hardware & Devices
Unknown Device in Device Manager/Show Hidden Devices
I have a Toshiba laptop, model L505-ES5018. I had Windows 7 Home Premium 64 bit installed on here, but decided to reformat my hard drive using Windows 7 Ultimate 64 bit. After the reformat was finished, I ran Windows Update and it found several items to download and install for me. I noticed...
Drivers
Device Manager reports Unknown Device & explorer crash
How do i figure out what driver or even component windows wants software for when in the device manager under other devices it lists an unknown device and windows update cannot find anything. Oh and is it appropriate for me to use this topic to ask another question regarding explorer.exe as...
Drivers
