#40
LOL, no problem mate. Yes, that would be correct that it doesn't have any bad sectors found then. :)
"that would be correct that it doesn't have any bad sectors found then" mean? sorry my english is bad really really sorry , then my harddisk is clean right ? no bad sector right? if the result "0 KB in bad sectors" and "0 bad file records processed."
Brink sorry for disturb you again, Today my Notebook suddenly not responding, and the notebook suddenly restart , not restart by me, then i try to chkdsk , and the result tell me to chkdsk /f ...
• this's the first result chkdsk
• after that i try to chkdsk /fCode:Log Name: Application Source: Chkdsk Date: 12/5/2012 2:19:05 AM Event ID: 26213 Task Category: None Level: Information Keywords: Classic User: N/A Computer: Frankz-PC Description: Chkdsk was executed in read-only mode. A volume snapshot was not used. Extra errors and warnings may be reported as the volume may have changed during the chkdsk run. Checking file system on C: The type of the file system is NTFS. The volume is in use by another process. Chkdsk might report errors when no corruption is present. WARNING! F parameter not specified. Running CHKDSK in read-only mode. CHKDSK is verifying files (stage 1 of 3)... 221184 file records processed. File verification completed. 2507 large file records processed. 0 bad file records processed. 0 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)... 282246 index entries processed. Index verification completed. 0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 3)... 221184 file SDs/SIDs processed. Cleaning up 368 unused index entries from index $SII of file 0x9. Cleaning up 368 unused index entries from index $SDH of file 0x9. Cleaning up 368 unused security descriptors. Security descriptor verification completed. 30532 data files processed. CHKDSK is verifying Usn Journal... 34837096 USN bytes processed. Usn Journal verification completed. The master file table's (MFT) BITMAP attribute is incorrect. The Volume Bitmap is incorrect. Windows found problems with the file system. Run CHKDSK with the /F (fix) option to correct these. 686489599 KB total disk space. 340803988 KB in 119670 files. 89944 KB in 30533 indexes. 0 KB in bad sectors. 344003 KB in use by the system. 65536 KB occupied by the log file. 345251664 KB available on disk. 4096 bytes in each allocation unit. 171622399 total allocation units on disk. 86312916 allocation units available on disk. Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Chkdsk" /> <EventID Qualifiers="0">26213</EventID> <Level>4</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2012-12-04T19:19:05.000000000Z" /> <EventRecordID>33429</EventRecordID> <Channel>Application</Channel> <Computer>Frankz-PC</Computer> <Security /> </System> <EventData> <Data> Checking file system on C: The type of the file system is NTFS. The volume is in use by another process. Chkdsk might report errors when no corruption is present. WARNING! F parameter not specified. Running CHKDSK in read-only mode. CHKDSK is verifying files (stage 1 of 3)... 221184 file records processed. File verification completed. 2507 large file records processed. 0 bad file records processed. 0 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)... 282246 index entries processed. Index verification completed. 0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 3)... 221184 file SDs/SIDs processed. Cleaning up 368 unused index entries from index $SII of file 0x9. Cleaning up 368 unused index entries from index $SDH of file 0x9. Cleaning up 368 unused security descriptors. Security descriptor verification completed. 30532 data files processed. CHKDSK is verifying Usn Journal... 34837096 USN bytes processed. Usn Journal verification completed. The master file table's (MFT) BITMAP attribute is incorrect. The Volume Bitmap is incorrect. Windows found problems with the file system. Run CHKDSK with the /F (fix) option to correct these. 686489599 KB total disk space. 340803988 KB in 119670 files. 89944 KB in 30533 indexes. 0 KB in bad sectors. 344003 KB in use by the system. 65536 KB occupied by the log file. 345251664 KB available on disk. 4096 bytes in each allocation unit. 171622399 total allocation units on disk. 86312916 allocation units available on disk. </Data> <Binary>00600300C64A0200CF4B040000000000DA0000003C0000000000000000000000</Binary> </EventData> </Event>
• at last cause i afraid not safe, i try to using this , My Computer > Local Disk C > Properties > Tools > Check NowCode:Log Name: Application Source: Microsoft-Windows-Wininit Date: 12/5/2012 2:26:43 AM Event ID: 1001 Task Category: None Level: Information Keywords: Classic User: N/A Computer: Frankz-PC Description: Checking file system on C: The type of the file system is NTFS. A disk check has been scheduled. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 3)... 221184 file records processed. File verification completed. 2507 large file records processed. 0 bad file records processed. 0 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)... 282256 index entries processed. Index verification completed. 0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 3)... 221184 file SDs/SIDs processed. Cleaning up 367 unused index entries from index $SII of file 0x9. Cleaning up 367 unused index entries from index $SDH of file 0x9. Cleaning up 367 unused security descriptors. Security descriptor verification completed. 30537 data files processed. CHKDSK is verifying Usn Journal... 34910928 USN bytes processed. Usn Journal verification completed. Windows has checked the file system and found no problems. 686489599 KB total disk space. 340798676 KB in 119669 files. 89948 KB in 30538 indexes. 0 KB in bad sectors. 344003 KB in use by the system. 65536 KB occupied by the log file. 345256972 KB available on disk. 4096 bytes in each allocation unit. 171622399 total allocation units on disk. 86314243 allocation units available on disk. Internal Info: 00 60 03 00 ca 4a 02 00 d3 4b 04 00 00 00 00 00 .`...J...K...... da 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 ....<........... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Windows has finished checking your disk. Please wait while your computer restarts. Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Microsoft-Windows-Wininit" Guid="{206f6dea-d3c5-4d10-bc72-989f03c8b84b}" EventSourceName="Wininit" /> <EventID Qualifiers="16384">1001</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2012-12-04T19:26:43.000000000Z" /> <EventRecordID>33444</EventRecordID> <Correlation /> <Execution ProcessID="0" ThreadID="0" /> <Channel>Application</Channel> <Computer>Frankz-PC</Computer> <Security /> </System> <EventData> <Data> Checking file system on C: The type of the file system is NTFS. A disk check has been scheduled. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 3)... 221184 file records processed. File verification completed. 2507 large file records processed. 0 bad file records processed. 0 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)... 282256 index entries processed. Index verification completed. 0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 3)... 221184 file SDs/SIDs processed. Cleaning up 367 unused index entries from index $SII of file 0x9. Cleaning up 367 unused index entries from index $SDH of file 0x9. Cleaning up 367 unused security descriptors. Security descriptor verification completed. 30537 data files processed. CHKDSK is verifying Usn Journal... 34910928 USN bytes processed. Usn Journal verification completed. Windows has checked the file system and found no problems. 686489599 KB total disk space. 340798676 KB in 119669 files. 89948 KB in 30538 indexes. 0 KB in bad sectors. 344003 KB in use by the system. 65536 KB occupied by the log file. 345256972 KB available on disk. 4096 bytes in each allocation unit. 171622399 total allocation units on disk. 86314243 allocation units available on disk. Internal Info: 00 60 03 00 ca 4a 02 00 d3 4b 04 00 00 00 00 00 .`...J...K...... da 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 ....<........... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Windows has finished checking your disk. Please wait while your computer restarts. </Data> </EventData> </Event>
- Automatically fix file system errors (Checked)
- Scan for and attempt recovery of bad sectors (Checked)
Result :
there's anything wrong with my notebook? sorry for the long message, please see Brink, and tell me there's any problem with my notebook or already safe? Thank You Very Much ....Code:Log Name: Application Source: Microsoft-Windows-Wininit Date: 12/5/2012 5:24:05 AM Event ID: 1001 Task Category: None Level: Information Keywords: Classic User: N/A Computer: Frankz-PC Description: Checking file system on C: The type of the file system is NTFS. A disk check has been scheduled. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 5)... 221184 file records processed. File verification completed. 2507 large file records processed. 0 bad file records processed. 0 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 5)... 282212 index entries processed. Index verification completed. 0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 5)... 221184 file SDs/SIDs processed. Cleaning up 12 unused index entries from index $SII of file 0x9. Cleaning up 12 unused index entries from index $SDH of file 0x9. Cleaning up 12 unused security descriptors. Security descriptor verification completed. 30515 data files processed. CHKDSK is verifying Usn Journal... 35184128 USN bytes processed. Usn Journal verification completed. CHKDSK is verifying file data (stage 4 of 5)... 221168 files processed. File data verification completed. CHKDSK is verifying free space (stage 5 of 5)... 86476126 free clusters processed. Free space verification is complete. Windows has checked the file system and found no problems. 686489599 KB total disk space. 340151160 KB in 119585 files. 89932 KB in 30516 indexes. 0 KB in bad sectors. 344003 KB in use by the system. 65536 KB occupied by the log file. 345904504 KB available on disk. 4096 bytes in each allocation unit. 171622399 total allocation units on disk. 86476126 allocation units available on disk. Internal Info: 00 60 03 00 60 4a 02 00 15 4b 04 00 00 00 00 00 .`..`J...K...... da 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 ....<........... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Windows has finished checking your disk. Please wait while your computer restarts. Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Microsoft-Windows-Wininit" Guid="{206f6dea-d3c5-4d10-bc72-989f03c8b84b}" EventSourceName="Wininit" /> <EventID Qualifiers="16384">1001</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2012-12-04T22:24:05.000000000Z" /> <EventRecordID>33476</EventRecordID> <Correlation /> <Execution ProcessID="0" ThreadID="0" /> <Channel>Application</Channel> <Computer>Frankz-PC</Computer> <Security /> </System> <EventData> <Data> Checking file system on C: The type of the file system is NTFS. A disk check has been scheduled. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 5)... 221184 file records processed. File verification completed. 2507 large file records processed. 0 bad file records processed. 0 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 5)... 282212 index entries processed. Index verification completed. 0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 5)... 221184 file SDs/SIDs processed. Cleaning up 12 unused index entries from index $SII of file 0x9. Cleaning up 12 unused index entries from index $SDH of file 0x9. Cleaning up 12 unused security descriptors. Security descriptor verification completed. 30515 data files processed. CHKDSK is verifying Usn Journal... 35184128 USN bytes processed. Usn Journal verification completed. CHKDSK is verifying file data (stage 4 of 5)... 221168 files processed. File data verification completed. CHKDSK is verifying free space (stage 5 of 5)... 86476126 free clusters processed. Free space verification is complete. Windows has checked the file system and found no problems. 686489599 KB total disk space. 340151160 KB in 119585 files. 89932 KB in 30516 indexes. 0 KB in bad sectors. 344003 KB in use by the system. 65536 KB occupied by the log file. 345904504 KB available on disk. 4096 bytes in each allocation unit. 171622399 total allocation units on disk. 86476126 allocation units available on disk. Internal Info: 00 60 03 00 60 4a 02 00 15 4b 04 00 00 00 00 00 .`..`J...K...... da 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 ....<........... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Windows has finished checking your disk. Please wait while your computer restarts. </Data> </EventData> </Event>
Hello sle3pingz,
It's not trouble at all.
Your log doesn't show any bad files or sectors. :)
It just means that your HDD doesn't have any bad sectors or damaged files on it.
If you wanted to help make sure that your system is clean, then you should also do a full scan with Malwarebytes Free.
yes i mean my HDD, safe right?
if clean or not, i scan with KIS 2013 Licensed can't?
