#60
OK, in that case maybe you should ask for help in this forum. Make sure you set your system to gather a mini dump as shown.
https://www.sevenforums.com/crashes-d...tructions.html
it greatly helped me thnxx brink...
thank you.
May I suggest that you recommend the use to install puush or lightshot instead?
I doubt that this is the only time they will need to screenshot something, and having a dedicated software for the job is really easing.
