Page 12 of 14 FirstFirst ... 21011121314 LastLast
  1. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #110
    You can also add the images in a post template now that they are in your albums
    Just use insert image and paste the url of the album image link.
    There is a limit on how many images can be in the album can't remember what that limit is 50 I believe ?
  2. Posts : 188
    w7 pro 32 bit w/XP virt enabled.
       #111
    Thanks, Ive not used the Album function before, from now on, I'll give it a try.
    Attached Thumbnails Attached Thumbnails Screenshots and Files - Upload and Post in Seven Forums-cheers-klx.png
  3. Posts : 188
       #112
    Selvan,
    Thanks, problem is solved, please where is Check Mark?
    See image below:
    Attached Thumbnails Attached Thumbnails Screenshots and Files - Upload and Post in Seven Forums-cheers-klx-chainwheel.png   Screenshots and Files - Upload and Post in Seven Forums-7-forum-top-listing.jpg
  4. Posts : 72,055
       #113
    Hello klxdrt, :)
    The "Mark as solved" button is only available in threads you created in the forum areas, and not in tutorials.
  5. Posts : 4,776
       #114
    You can only "Solve" threads that you started:
  6. Posts : 188
       #115
    Brink,
    Didn't know that.
    Attached Thumbnails Attached Thumbnails Screenshots and Files - Upload and Post in Seven Forums-sorry-2.jpg   Screenshots and Files - Upload and Post in Seven Forums-cheers-klx-chainwheel.png
  7. Posts : 60
    Windows 7 Pro 64 bit
       #116
    Attached file size limits
    I see that the file limit size for jpg's is 2.0MB .
    Is that per file?
    Or ...
    Must the sum total of all jpg's attached total
    no more than 2.0MB ?
    Thanks!
  8. Posts : 20,583
       #117
    As far as I'm aware it is a per file limit not a total of all.
  9. Posts : 51,482
    Windows 11 Workstation x64
       #118
    Per file.
      My Computers
  10. Posts : 60
       #119
    Ok, thanks!
