#120
what if the file size is more than 2 mb say 52 mb.
Hello qpod,
You could see of zipping the file may reduce it enough to meet the max size for .zip files.
Otherwise, the file will need to be reduced in size depending on its file type, or use a hosting site to link from.
other than hosting site is there other solution.
its a CBS folder size 938 kb
CbsPersist_20180716023334 size 2609 kb
CbsPersist_20180716025236 size 6585 kb
CbsPersist_20180716030850 size 2054 kb
CbsPersist_20180716061717 size 11920kb
CbsPersist_20180716064432 size 8918 kb
FilterList size 1kb
original file size is 32 mb
after using winrar or winzip it is compressed to 26.8 mb
which is still way more than 2 mb.
If this is for SFC, then you could use Option Three in the tutorial below to get only the SFC details from the CBS log to make it much smaller.
SFC /SCANNOW Command - System File Checker - Windows 7 Help Forums
I have no idea as to how to jump through all those hoops. I can send the screen shot to your email, as the HELP site says the file is too big.
