Driver Install - Add Printer Wizard
    How to Install a Driver in Add Printer Wizard
    NOTE: For this example, I am installing the Cannon BJC-1000; I will be Using Windows XP drivers.
    1) Click on Here.
    2) Click on Add Printer.
    3) Click on Add a Local Printer.
    4) Click on Next.
    5) Click on Have Disk.
    6) Click on Browse.
    7) Click on Computer.
    8) Click on Open.
    9) Click on OK.
    10) Click on Next.
    11) Click on Next.
    12) Click on Finish.
    13) Restart your PC
  1. Posts : 6,618
    Correct me if I'm wrong, but Windows already recognizes the printer. There is no special driver for my printer, it uses a Windows native driver. Instead of using the Add Printer button, I tried using the Add Device button, but all that does is to produce an empty window that says that it is searching devices, but from CPU/hard drive activity, it appears that nothing is happening.
  2. Posts : 11,408
    ME/XP/Vista/Win7
    I do not have a All in one, to test with.
  3. Posts : 2,566
    Win 7 Pro x64 SP1 OS X Snow Leopard 10.6.7
    Usually depends on the printer. Some printer requires CD in order to be working. Some require through Device and Printers wizard.
  4. Posts : 97
    I'm trying to install a Brother HL-1250 printer on a Windows 7 64 bit system and this wont work...
  5. Posts : 72,052
    Hello Clay,
    According to the links at Brother below, the HL-1250 will have a Windows 7 driver available for it through Windows Update, and does not have one available for download at Brother.
    Windows 7 Compatible Models | Brother
    Install the Windows® 7 built-in drivers from the Windows Update provided by Microsoft: Brother
    Hope this helps, :)
  6. Posts : 97
    Brink,I tried all that and cant get it to work..What am I doing wrong?....
  7. Posts : 72,052
    What does it say or do when you try this below?
    What doesn't work when trying it?
  8. Posts : 97
    It doesnt work no matter what I do...It dosent see the printer and every thing it says to click on is wrong.I will have to do without a printer...
  9. Posts : 9
    Windows 7 Home Premium 32bit
    It works for me.. Thanks for this guide.. Well, To ensure all of your hardware remains up to date, see Automatically get recommended drivers and updates for your hardware.
